Page 2 of 2 FirstFirst 12
Results 41 to 74 of 74
  1. #41
    Dec 2015
    St. Peters, MO
    3,325
    My rustler has Hobbywing motor and vxl 6s esc. I had a sidewinder 8th in it and it was horrible on anything over 3s it kept shutting down. Even tried reverting back then updating software vrs. So now i have vxl6s in it(havent taken it out yet).
    Had a castle sct combo in p4de and it hated 3s but drove it 3s anyway, month later, 3800kv motor was in trash can and I got an sc8 esc which ive been impressed with and a kershaw 2700kv motor which is one of the best purchases ive made. Run on 4s with no issues.
    The wifes slash has the Trx Vel sys with 3500kv and on 2s is perfect. For it.
    In a nutshell, in my opinion & experience the lowest kv you can afford with highest power esc you can afford. Then you have options from 2s batts and tame gearing to at least 4s(with most decent 980-120 amp esc's with slightly aggressive gearing and dont have to worry about heat issues.
    I need just one more rc, then Im done,
  2. #42
    RC Qualifier Amistry20's Avatar
    May 2017
    331
    i cant seem to find the leopard 3800kv, So leapard is the brand to go for? good performance at low cost? is that right
    http://www.ebay.com.au/itm/Brand-New...kAAOSwVFlUDtyV
    that is the 3600kv, is that good with the max 10 sct
  3. #43
    May 2017
    331
    http://www.ebay.com.au/itm/1-8-RCCAR...oAAOSwBLlVAavH
    opinions?? will the motor fit?
    If i can find a low kv with the sc8, it will be an option
    if not, the max10sct will have to do, with something like a hobbywing 3200kv or leopard 3600kv
  4. #44
    Oct 2016
    4,125
    That can may not fit. Mine does but I don't run the stock tranny case. The 1512 is a 2650kv. You can always modify the gearbox and make it fit.
  5. #45
    Apr 2016
    Midwest
    1,006
    I agree with Grip, I tried mounting a 2200kv and it didn't work, then I tried a 2650kv and still had to some modding.
    "Gone racing"
  6. #46
    Rotterdam, Netherlands
    8,617
    Quote Originally Posted by Amistry20 View Post
    This is a 2858 motor which means, in case of Leopard motors, a length of 58mm and a diameter of 28mm. It can deliver 780W which will not be much of an upgrade. I meant the 3660 Leopard one, which you linked to in post #19.
    Leopard is a good quality brand with very affordable prices in my experience.
    The Castle 2650Kv is a great motor, but not a direct fit. You have to dremel parts from the chassis before it fits.
    That is a combo with a price which is lower than what you normally pay for the motor alone.
    Rule of thumb: most of the time if something looks too good to be true, it appears too good to be true.
  7. #47
    May 2017
    331
    oh ok, if i can find a good deal with the sc8, than ill go with that as the combos seem to be cheaper. If i have to buy a motor seperatly, than ill go with the max 10 sct. Just to make it clear what esc i have decided on. How about a castle motor with the max 10 sct? i am not going to go 1/8 scale motor because i dont want to modify my gearbox
  8. #48
    8,617
    I switch too much between the Pede 4x4 forum and the Rustler forum. What I said about the 2650 goes for the Pede 4x4 chassis. You indeed need a different or modded gearbox for it in case of the Rustler.
    I would never use a 2650 for a Rustler except when I wanted to do speed runs. It's a quite heavy motor.
    The combo of post #19 has a motor that will fit without gearbox mods.
  9. #49
    May 2017
    331
  10. #50
    Oct 2016
    4,125
    That motor is a 1/8th motor. You should use the 3200 Leopard with the sc8. IMO. I only run the 2650 because it's a speed car. It's a Heavy car now. Don't get me wrong, it's a sick setup but it doesn't sound like that's what you're after. My 4x4 pede is my basher, and I still use the VXL setup from the Rustler in that. I'm going with Leopard or Kershaw when I kill the VXL.
  11. #51
    8,617
    Since you are coming from a brushed combo, I would never make the huge step to a 1/8 combo like Grip explained.
    You can jump from a go kart into an F1 car, but if that is wise.....
  12. #52
    May 2017
    331
    Lowest kv motor? for the max 10 sct?
    all i can find in a low kv are 1/8 scale motors
  13. #53
    Oct 2010
    3,144
    Wow, I'm a week late to the party. For me, I have a Castle Creations Mamba X with a Castle Creations Neu-Castle 2400kv motor running on 3S. I have these systems in my Sla2h, Rusty, and P2de. Pure bliss.
    Obstacle Magnet
  14. #54
    May 2017
    331
    the mamba X is way out of my budget, that is why i am going with the max 10 sct. I wont be using anything crazy, only 2-4s,but primarily 2s. will the neu castle 2400kv fit in the rustler without modifications?
    http://www.ebay.com.au/itm/Castle-Cr...QAAOSwll1WwdzE
    if that worked with the max10, i would be soo happy
  15. #55
    Oct 2016
    4,125
    The esc you're looking at is 3S max, and 60 amps is fairy weak. Save a little more money you'll be happy you did.
  16. #56
    May 2017
    331
    no, i ment the max10 sct, which is 120 amp. Do you think the motor will fit? i dont mind dremeling the drivertrain.
  17. #57
    8,617
    Quote Originally Posted by jvogel View Post
    You have the sensored combo?
  18. #58
    Oct 2016
    4,125
    Get the motor specs and measure. I'm almost positive you can make it fit, you just may need to notch out the tranny case in the back.
  19. #59
    May 2017
    331
    So, is this the best combo possible for the money?
    Sorry for going back a step but, what kind of speeds will I get with a sidewinder sct waterproof 3800kv?
  20. #60
    May 2017
    331
    Sorry for double post, but
    http://www.ebay.com.au/itm/Castle-Cr...sAAOSwcB5ZEnkI
    is that good deal? because it is way inder my budget. What speeds will i get? on 2s will i get around 40-50 mph? because that will be good enough for what i am paying
  21. #61
    Oct 2016
    4,125
    Yes, that's what it'll be. 2S. Get a 76 spur and 22-28 pinion. You'll be scootin
  22. #62
    May 2017
    331
    so 40-50 on 2s??
    i would only run 3s on a really cold day.
    I will just go with that as it is so cheap!
    i am still using nimh, any lipo charger recemondations
    http://www.ebay.com.au/itm/Ultra-Pow....c100033.m2042
    i was thinking of getting this
  23. #63
    8,617
    No experience with the brand, but specs look fine.
  24. #64
    May 2017
    331
    what chargers do you use Petertje60 ??
  25. #65
    May 2017
    331
    Ive been doing some research and i cant decide between the Traxxas Velineon vxl-3s or the castle sv3
    the Velineon seems faster but people say the castle is better
  26. #66
    Oct 2016
    4,125
    They're both good. Choose what you want.
  27. #67
    May 2017
    331
    sc8 with castle 2400kv???
  28. #68
    Oct 2016
    4,125
    Do it. Just know you may be modifying the gearbox
  29. #69
    RC Champion Dcuda69's Avatar
    Jan 2015
    WI
    2,948
    Here's another combo that I think would run well on 2s and an occasional 3s(geared properly) The HW WP SC8 will allow room to grow in the future if desired and can be had with a program card that makes adjustments a breeze, also comes with a fan
    http://www.ebay.com/itm/Hobbywing-EZ...0AAOSwmLlX7cY5
    This motor should move that Rustler just fine. I have the 1/8th scale version(2150kv)in my Slash and it's been great. This is only $30 so not like you'll have big money invested.
    http://www3.towerhobbies.com/cgi-bin...?&I=LXETXT&P=3
    You'll have a solid esc for the future and about $100 in the whole set-up. Good luck!
    Slash 4x4 Ult 2150kv
    Rustler vxl
    Ford GT vxl
  30. #70
    Oct 2016
    4,125
    At the end of the day, you'll have to make the decision. You've been given tons of advice. If you're going brushless and plan to stay on 2S. Dcuda's last suggestion will be great. If you want to increase voltage you're going to want(need) a lower kv motor. 100 bucks for a brushless setup is awesome.
  31. #71
    May 2017
    331
    Ok, so i found another thread and found a really good combo
    The hobbywing sc8 and the Tenshock sc401 3400kv
    people say it is really good
    i am going to stop my questions now because i have finally decided
  32. #72
    Jan 2015
    WI
    2,948
    That sounds like a solid choice. Post back after you run it and let us know what you think. Have fun!!
    Rustler vxl
    Ford GT vxl
  33. #73
    May 2017
    331
    :P i didnt end up getting the combo, another traxxas user "zeus" kindly donated his old velineon system to me
    Runs great
  34. #74
    Dec 2017
    110
    I heard good things about gool rc's brushless system.
