Page 1 of 4 123 ... LastLast
Results 1 to 40 of 130
    Aug 2017
    455
    Aqualungs New Stampede 4x4 VXL Build
    Just ordered a Stampede 4x4 VXL last night on eBay:
    https://www.ebay.com/itm/132277715060
    Pretty excited and my first RC for off-road. I have a couple helicopters. Was going for a slash at first, but I wanted something that would go off-road more than on road. After watching videos the ability to do flips, run in snow, my backyard, wooded trails, etc. I would enjoy this more than pavement/dirt racing.
    So a 189$ 2wd brushed Slash led to this..
    Shopping for chargers that do lipo/nimh. I think I may start with two Nimh batteries. I can be absent minded. So for starters that might be a safer bet. Please feel free to make any helpful suggestions. I set alarms to remember things.
    Upgrades I plan on doing almost immediately:
    -Body lowering kit
    -Proline Tires for off-road(maybe trenches, so I can use and wear out the stock tires when I play on the pavement.
    -Aluminum shock caps?
    Thanks for all the help in Advance.
    Marty
    RC Qualifier Bige4u's Avatar
    Jan 2017
    Texas
    426
    Congrats on the purchase...
    Your running brushless, forget using Ni-MH batteries, go straight for LIPOs, more power and much better run times, and as for a charger, are you planning to sticking with traxxas brand batteries and use their matching chargers or going aftermarket, i suggest aftermarket for both.
    Charger - http://hitecrcd.com/products/charger...harger/product
    Batteries - http://www.smc-racing.net/index.php?...tegory&path=67
    Aluminum shock caps, proline trenchers tire/wheels set, shoe goo/drywall tape the inside of the body to reinforce the lexan body for longevity with hard plastic washers at the post holes, MIP x-duty axles, the traxxas fan for the ESC to keep the temps in check and going with the aluminum bearing adapter for the slipper clutch.
    Bashing along @ 30mph...
    Aug 2017
    455
    Quote Originally Posted by Bige4u View Post
    Thank you. I take it you need the 2938 adapters to connect the SMC batteries to the Stampede?
    Aug 2017
    455
    I will probably go aftermarket encase I buy another brand that can't be mentioned here. I want to build a crawler.
    Jan 2017
    Texas
    426
    The use of adapters is not recommended, if you can order the aftermarket battery with the type of connector that matches the ESC, its better... or you can cut and solder on your own matching connectors, but that of course will void the warranty of the battery because it will be considered modified.
    Nothing wrong with using the traxxas batteries if you want to keep the same connectors w/o having to change them over, just make sure you get the hardcase version and get the traxxas charger as well to keep everything matched.
    Aug 2017
    455
    I like what I hear and see about SMC. I can order them with connectors.
    I wanted to get a decent starter charger at first and save for a good one. That way I'd have a backup/travel charger. What about SMC's H100?
    http://www.smc-racing.net/index.php?...product_id=446
    Thanks again!
    Dec 2015
    St. Peters, MO
    3,467
    Welcome to the hobby, Trx family and addiction! Lol. Here is my list of recommended upgrades. Just skip the first paragraph since its a vxl and already brushless. https://forums.traxxas.com/showthread.php?p=6406101
    Here is my charger setup. https://forums.traxxas.com/showthread.php?p=6403694
    Heres 2 threads about lipos. https://forums.traxxas.com/showthread.php?p=6404088
    Happy bashing, enjoy it!
    I need just one more rc, then Im done,
    Jan 2017
    Texas
    426
    Quote Originally Posted by Aqualungs View Post
    Thanks again!
    Im not familiar with SMC's chargers, googled for reviews, none can be found for that peticular one, but it should be a good choice for the price though, that company sells quality premium products... they do charge $12 for shipping on their lipos, not sure about their other items.
    Aug 2017
    455
    I guess I'll be the guinea Pig and post my thought on the SMC charger. I ordered that and 2 - 2c 7200 mah 90c 7.4 volt batteries with Traxxas connections
    Dec 2015
    St. Peters, MO
    3,467
    That is a good inexpensive price for a charger and I dont deny SMC products are good quality, but you generally get what you pay for. I did extensive research before my first charger purchase and going with the Hitec has been a choice I will never regret. I cation you to that charger it shows a max of 8a for 3s(I dont know why it shows those specs when it says its a 10a charger though). So the biggest 3s lipo id recommend is 8000mah or lower for lots of reasons, but mainly because batt manufacturer suggested charge rating of 1c for a 8000mah batt is 8amps. We can discuss more in depth if wanted but id encourage to read through lipo threads first. Obviously go with ones that are in your price range and I have no experience with smc chargers, so just look at reviews and do your research. I can say for up to 8amp the Trx charger is decent and really user friendly. Kinda like Iphone. But if you want a model with more options(like android) then look at other chargers. Lol! I dunno i may have just hurt my case there knowing the amount of die hard i-product ppl there are in this world. Just being funny dont be haten on pleeeease Lmbo!
    Aug 2017
    455
    Quote Originally Posted by Briber View Post
    Good to know. I was looking at Hitec also. They are the same price. I figured they have good batteries, charger must be good too.
    Jan 2017
    Texas
    426
    Briber... yes the SMC charger says 10a, but you have to remember a thing called the POWER law, the more cells you charge, ie, increased voltage, the less current you have available to use.
    Example...
    10a(100w)
    2s(7.4v/8.4v full) - 100w / 8.4v = 11.9a (but remember you only have 10a available)
    3s(11.1v/12.6v full) - 100w / 12.6v = 7.9a (up to 7900mah @ 1c)
    4s(14.8v/16.8v full) - 100w / 16.8v = 5.9a (up to 5900mah @ 1c)
    5s(18.5v/21.0v full) - 100w / 21.0v = 4.7a (up to 4700mah @ 1c)
    6s(22.2v/25.2v full) - 100w / 25.2v = 3.9a (up to 3900mah @ 1c)
    Get it? Got it? Good
    EDIT - POWER LAW = watts / voltage x current
    Aug 2017
    455
    Example...
    10a(100w)
    So this charger would be ok ?
    Dec 2015
    St. Peters, MO
    3,467
    Example...
    10a(100w)
    Got it.
    But the Hitec x2 is 200w on dc. So with converter or charging on car batt the power/current is there, yes?
    That with wifi module and dc charging capabilities = better charger....
    Yes smc charger is just fine, its what ever fits in your budget. Its 45 for SMC or 100 for x2 and 130 for x2 pro.
    Jan 2017
    Texas
    426
    Yes... the SMC charger will be just fine.
    Just remember the total voltage(#s) and MAH rating of the lipo, is what determines the charge amount and time at 1c or less according to the charger you use, power(watts) wise.
    Aug 2017
    455
    Thanks guys. I've been reading up on lipos and the links you guys provided to learn more. Picking up some lipo bags off of eBay.
    https://www.ebay.com/itm/252814010334
    Couple more questions about upgrade parts. I am going to order the shock caps, aluminum bearing adapter, and esc fan right away. Should I also upgrade to 17mm hub adapters now, or when I get the Proline trenchers?
    Last of all is lowering the body to close up the gap a good upgrade. I imagine it would lower the center of gravity a little bit. Is this the right kit? I like the aluminum twist caps!
    https://www.ebay.com/itm/361638375035
    Or this one?
    https://www.ebay.com/itm/401314678606
    Dec 2015
    St. Peters, MO
    3,467
    Or this one?
    Lowering body really wont lower center of gravity since body weighs next to nothing. To lower center of gravity the chassis needs to be lowered. I wouldnt do 17mm hexs & wheels until after drive shafts are upgraded. The upgraded wheels will add more stress to drive shafts.
    Aug 2017
    455
    I definitely wanted to keep the ground clearance and not lower the chassis, I saw someone mention a lowering kit to cover the gap.
    Will do in the axles and wheels. I'll be waiting a little while to do that. I spent enough lol!
    I'll just pick up these items and call it a day:
    -aluminum shock caps
    -6893x aluminum bearing adapter
    RC Champion lektro's Avatar
    Nov 2016
    Virginia Beach/ South USA !
    1,922
    Or this one?
    Why buy the whole kit to lower the body. Just take the stock posts off and run screws up from underneath. If you look in your second link, All you need are the caps for 6 bucks.
    This is how far that would lower your stock body.
    One thing about the posts and I don't see how the new mounts in your links would make a difference. The caps do not fit on the rear of the stock body without a modification, cutting part of the body out. It just wont fit!
    Choose Life !!!
    Aug 2017
    455
    Quote Originally Posted by lektro View Post
    Nice looks good. She. You say run the screws underneath, do I need to predrill or are the holes open from underneath. I saw so threads on this. I will look More into it
    Nov 2016
    1,922
    Yes the posts that are there now have screws in them. You need to use a screw that fits the cap. In my tool set i have reamers. stick it in the hole and ream. lol Make them just a tad larger. Then force the screw in. It will be tight as a tick.
    A must have tool for the RC guy.
    Choose Life !!!
    Nov 2016
    1,922
    You can also take the stock posts off and these are a direct fit. If you want to use clips.
    Choose Life !!!
    Aug 2017
    455
    I was looking into the twist caps, instead of clips
    Nov 2016
    1,922
    Yes sir I know. I was just showing you these as an option... On my 53 Chevy body, the caps work great. Like I said earlier they dont fit the stock body unless you cut it or find some smaller diameter caps.
    Choose Life !!!
    Dec 2015
    St. Peters, MO
    3,467
    Agreed, i didnt buy whole kit either just caps, i cut nipple off that pin goes through, drilled a hole and set stud. If you use the stock holes in mount bracket to attach posts the caps will fit in stock body holes(see pic of blue truck, i didnt move posts and used stock body holes). But its hard to get off sometimes.
    Nov 2016
    1,922
    I tried putting the caps on with the stock body and can't get them even close to going on. Maybe I should try again Briber. I am coming very close to cutting on the stock body as this will be my do all body. I am nearly done with my minor upgrades and will be ready to get this thing dirty real soon. I have the Tekno center drive shaft but will wait for the stock one to break first. I have o rings on shaft mounts to where it has no back and forth play. Maybe it will last longer this way. Not looking forward to paying close to $150 for front and rear drive shafts either. BUT I "will" see how long the stocker's last.
    Choose Life !!!
    Dec 2015
    St. Peters, MO
    3,467
    Hmmmm Ive done it on 3 different p4des ive never made new holes in body or moved post from original mount bracket holes. Im getting ready to get 2 new bodies for my pedes so ill see whats up. That is a proline body maybe holes are slightly more narrow. But my other body is the stock pro-graphics body. I dunno smh on that one. Mip xduty drives should run you about 100.
    Nov 2016
    1,922
    Yeah my 53 Chevy body has plenty of room for the caps. All i did was run screws up through the body mount arms, so they are in the same place. If you look at the last pic in post 19 you can see why. Hmmmmm is right After taking another look I could move the screws in about a 1/4 in and make new holes in the body. Better than cutting on it. then i will re-enforce the existing holes. hmmmm good idea!
    Choose Life !!!
    Dec 2015
    St. Peters, MO
    3,467
    You got this! Sounds like a plan. Yea reinforcing it adds strength so shouldnt have any issues with old holes.
    Aug 2017
    455
    Cool suggestions guys. Is there a Pro-Line kit that allows you to lower the body and use the twist caps?
    Nov 2016
    1,922
    You have 2 links in post 16 but it only lowers and raise's the body. Don' think it has adjustments to move them any other way.
    Choose Life !!!
    Aug 2017
    455
    Right. Those were the only 2 I found that might work. I'll see when the RC gets here. Be easier to look at what I'm dealing with
  33. #33
    Aug 2017
    455
    Here's a silly question. Everyone does shock caps, but the GTR shocks are only 27$ more. Are the GTRs Amy better than the stock shocks?
  34. #34
    Aug 2017
    455
    This is the best explanation
  35. #35
    Oct 2016
    4,781
    I got the kit because I got my pede and they were well worn. The caps don't come close to fitting the stock body. This is as low as I can get mine. I got the slash kit because it's lower. Needed new holes up front. I'm good with it
  36. #36
    Aug 2017
    455
    That looks great!
  37. #37
    Oct 2016
    4,781
    That looks great!
    Thanks. I try. The bodies are disposable/consumable. Treat them as such.
  38. #38
    Nov 2016
    1,922
    Hey Grip< I have seen your truck numerous times. This is the first time I noticed the extra set of holes. It is just a body and definitely disposable. I will find a way to make my stock body fit. I will also be using the Chevy body for the same thing. Smashing and bashing. Of course, I will wear out the stocker first. Can you mail me one of those bananas please
    Choose Life !!!
  39. #39
    Oct 2016
    4,781
    Yeah I got the kit after the body. It's best now anyways. Careful I have your address
  40. #40
    Nov 2016
    1,922
    LOL I guess it should be ripe by the time it gets here ya think!
    Choose Life !!!
