Page 4 of 4 FirstFirst ... 234
Results 121 to 130 of 130
  1. #121
    RC Champion zedorda's Avatar
    Sep 2015
    S.E. Michigan
    1,412
    It does replace the aluminum one and isn't used with the center diff.
  2. #122
    Aug 2017
    455
    Good to know! Iím going to rebuild the slipper clutch for a back up or when I want to be wheelie happy.
  3. #123
    Aug 2017
    455
    Speaking of slipper clutch throwout bearing seized up
    Not sure if it was dirt or if it just overheated and expanded
  4. #124
    Aug 2017
    455
    Wrong picture?
    Got the rear end almost stripped down and cleaned. Bagging the different parts with their screws. Disassembling the MiP rear axles was no fun lol. Lots of sand. I like the simplicity of the Teknos I have on front. Looks like this will be a nice fall project. I may be avoiding sandy beaches from now on. Lol
  5. #125
    Sep 2015
    S.E. Michigan
    1,412
    Sand is an evil mistress to RCs.
  6. #126
    Aug 2017
    455
    Sure is! All the bearings so far in the rear hub carrier and diff need replaced. The ones in the hubs I did last winter I think. Diffs.. theyíre the originals and the truck will be 3 next May. Oops. Lol
    I wonít be playing in sand again until itís time for a strip down. Sheesh.
    Time to pick out some some bearings and seals.
  7. #127
    Aug 2017
    455
    Finally destroyed my body lol. Ordered the black Proline F100 to save myself some time painting. Snow is around the corner. Also rounded out a wheel, so I ordered a pair of new Mashers for the rear, since the wear is still good on The other ones. I like that the hubs are now replaceable on the new ones since the tires last so long.
    Had a little issue with the gear cover not sitting right in a couple spots with the King Kingheadz motor mount. Almost as if the cover is warped, but its new. It let some debris in and stripped out my spur gear in 2 runs. The gaps are about 2mm. Never happened with the old setup. Any ideas? For now I put down some silicone and placed the cover on. Works good for now.
    Sent from my SM-N975U using Tapatalk
  8. #128
    Aug 2017
    455
    66 Ford F100 black body almost done. Going to put a little extra reinforcement ment on a a few spots. Then lift the peel
  9. #129
    Aug 2017
    455
    Goodbye 72 Chevy, hello 66 Ford! Sticker time!
  10. #130
    Aug 2017
    455
    Ready for battle tomorrow
