Results 1 to 7 of 7
    Sep 2017
    U.S.A
    7
    Will slash bodies fit the rally?
    I have noticed there is a great selection of bodies for the Traxxas slash. However the are pretty much only the stock Traxxas ones. Is there a way I can put a nice slash body on my rally?
    RC Qualifier Myrustlervxl's Avatar
    Dec 2016
    Ohio
    500
    If you have a Traxxas rally and not a Deegan then you have to get Slash 4x4 body post for the rear maybe the front but I'm not 100% sure then if you want to go slash then you have to get the front and rear bumpers
    Sent from my SM-G930P using Tapatalk
    Good work isn't cheap, cheap work isn't good
    RC Qualifier spunkybob's Avatar
    May 2016
    605
    The rally body uses a different rear body post.
    Get the slash ones (or RPM/proline mounts) and you should be good to go.
    Sent from my SM-G935F using Tapatalk
    Jan 2015
    79
    Both bodyposts are different indeed. Also, the different front bumper affects the fitting of bodies too. Then again, it's easy to replace the rally bumper with a slash one.
    Sep 2017
    U.S.A
    7
    Quote Originally Posted by spunkybob View Post
    Should i get the "extended mounts" or the regular ones?
    May 2016
    605
    Quote Originally Posted by Jamcm8 View Post
    Depends what body you want to run. If standard type bodies just get normal if the true scale bodies from.proline I think you need the extended ones.
    RC Turnbuckle Jr. jvogel's Avatar
    Oct 2010
    PM me if you want to bash near Grass Valley, CA
    3,144
    I have switched my Rally into an LCG Sl4sh and back again many times. I recommend the Pro-Line adjustable posts with their Secure Loc caps.
    Obstacle Magnet
