Results 1 to 14 of 14
    Sep 2017
    6
    Biggest problem with the 4 tec 2.0
    Haven't heard anyone complain about this but it has proven to be an issue for me
    The chassis collects A LOT of stones.
    Not a big deal, I thought at first. Pick the car up and flip it over...problem solved. Not exactly!
    Sometimes stones of just the right size will lodge themselves between the floor pan and the steering linkage causing your steering to lock
    In two instances this caused two servos to short
    Next step for me is finding a chassis dust bag. Got do some research and see if one exists for this car
    Jun 2009
    89
    Quote Originally Posted by Marshal View Post
    Just use some Velcro and Velcro some screen mesh over your chassis like those outerwear things
    Jul 2017
    93
    It does collect a lot of pebbles.....typically I flip mine upside down after running to "clean" it
    RC Racer rustlerstein's Avatar
    Jan 2016
    Wisconsin
    228
    Mine burned up a steering servo that traxxas warrantied right after I got it.
    Another problem I've had is with the rear tires catching the back bumper when the tires balloon out.
    Breaking parts one run at a time
    Sep 2017
    6
    Quote Originally Posted by Jigaju View Post
    Yeah, something like that will have to work. I can't seem to find any sort of chassis cover from a retailer.
    Just toasted another servo and I've got a savox on order....that one I'm not going to fry. I'll have a solution n place prior to running it
    Nov 2016
    22
    Wow and I thought it was just me. I had a stone get stuck against the center driveshaft. It put a few grooves in the shaft but seems to be OK
    Aug 2016
    Houston, Texas
    607
    I use mine to vacuum the floor... but seriously it does collect a lot of small debris. Even on the track after they blow it off with a leaf blower, my 4tec seems to still collect a lot of stuff. I had things get stuck in the steering, and in the center shaft running in dirty parking lot. I think there might be a way to make a mesh or fabric cover for the steering. Maybe even one for the shaft.
    Dec 2016
    ohio
    75
    hey Marshal what savox servo did you go with
    Oct 2017
    88
    Solution...I cut out the floor pan underneath the linkages.
    I’m sure it’s weaker now but unless I get into a high speed front collision with an immovable object, I’ll be fine
    May 2019
    Quote Originally Posted by Svtcobra View Post
    Iím sure itís weaker now but unless I get into a high speed front collision with an immovable object, Iíll be fine
    Exactly the resolution that came to mind when reading the issue. Can also get Le an by the sheet and make 1Ē or so strips that attach to the edge of the chassis to work as an inter wheel well of sorts.
    May 2019
    Speaking of half shafts. Know if carbon fiber shafts are available anyplace?
    Jun 2020
    9
    Glad to see I am not alone 3 servos, 2 in a week. One stone and 1 small piece of wood. Going to cover that area with some.
    Sep 2017
    119
    Wow, i thought it was just me, i run on a really smooth black top car park but little stones seem to be forever chogging up my steering linkages, after about ten laps i stop her for shake and hundreds off little stones shake out.
    You don't need massive expensive servos on this platform either, i run a futaba s3003 cheapo and it's going strong on two years.
    Good idea about the mesh, may try a pair of the wife's tights, clean ones, lol.
    Sent from my POT-LX1 using Tapatalk
    Aug 2020
    Kansas City
    130
    After reading this, I am going to order one.
    Google/Amazon: RC Nylon Mesh Chassis Dirt Dust Guard Cover and you will get a lot of results/reviews.
