Results 1 to 21 of 21
    RC Qualifier Amistry20's Avatar
    May 2017
    331
    Cool New shocks for rustler????
    My ultra shocks have started to leak and I have popped the caps off too many times. I don't want to spend the money getting the aluminium caps as it would be better getting new shocks.
    I was thinking along the Traxxas gtr, are they better than the big bores?
    I was after threaded bodies for easy adjustment
    I would want something a bit bigger and heavier than the Traxxas big bores
    something around the gtr size.
    And something that can take a good beating
    Do you guys have any recommendations?
    I was thinking about the proline power strokes, but they are way out of my budget. How do they compare to the Traxxas shocks? if they are much better, I will probably get those.
    I have found the gtr's much cheaper than the big bores, so should I
    get those?
    Thanks for the help guys!
    Jun 2016
    North Jersey
    670
    I vote for the GTR's.
    RC Qualifier Myrustlervxl's Avatar
    Dec 2016
    Ohio
    500
    I like my GTR's over the shock rustler
    Sent from my SM-G930P using Tapatalk
    Good work isn't cheap, cheap work isn't good
    RC Racer SilentRunner007's Avatar
    Dec 2015
    NJ
    196
    Quote Originally Posted by Blown94 View Post
    GTR's are nice....for my Rustler I bought all new parts using STRC Threaded aluminum shock bodies and Traxxas coated shock shafts and piston/seal kits.
    3RusterXL5
    4Nitro4Tec
    "Snap On"Alias
    Craniac
    Dec 2016
    Ohio
    500
    https://r.tapatalk.com/shareLink?url...1&share_type=t
    How I made GTR shocks work on myrustlervxl
    May 2017
    331
    Thanks guys, so the revo and jato gtr shocks wont work on there?
    So will i have to get the slash gtr shocks for it to work?
    Oct 2016
    4,681
    Get long for the front and xl for the rear. If you look on tower they give lengths.
    May 2017
    331
    Gtr's dont fit, will they? So i might get proline power strokes for the front and gtr's for the back?
    Does that plan sound good, this way, it will all fit
    Oct 2016
    4,681
    I run GTR's on front and rear. Just as stated above and countless people use.
    May 2017
    331
    ok, but which gtr's will fit the front A arms, Myrustlervxl said that he had to change the ball pins, will that be the case if i use the gtr shocks from the slash 4x4
    Dec 2016
    Ohio
    500
    Yes, if you order slash 4x4 GTR shocks the only way I know to make them fit is to swap out the ball pins and get a screw with no collar for the all four upper mount. I heard of other people grinding down there a arm to make it fit, that's something I did not want to do. In my opinion the GTR shocks are worth it for the money it's not hard to press that pin out and put the other one in there, and for the screw there's a part number on there for traxxas screw or .you can just go to the hardware store and try to find something that'll work. I think you will be very happy with GTR shocks and save the money and buy other upgrades for your Rustler.
    Dec 2016
    Ohio
    500
    By The Way Slash 4x4 GTR shocks are the ones you're looking for.
    Oct 2016
    4,681
    Dude that's changing a couple 50 cent parts. But yes you do need to swap lower mount balls out. Either that or modify the arms with a dremel
    May 2017
    331
    I just stumbled across this video,
    https://www.youtube.com/watch?v=0iRE2rAQH0o
    Will i encounter the same problems on the rustler?
    I ask way to many questions
    Sep 2015
    2,308
    Quote Originally Posted by Amistry20 View Post
    GTR springs are pretty bad IMO, and wear out super fast. If you get better springs, you should be fine.
    youtube.com/c/RazorRCvideos
    Dec 2016
    Illinois
    244
    Atomik Rc makes really cheap high quality shocks for the rustler. They are 14.00-18.00 dollars for 2 shocks.
    Oct 2016
    4,681
    Quote Originally Posted by RazorRC22 View Post
    I'm surprised to hear this. I've never heard anything but positive feedback from them. But since you're a racer, I could see how you'd know. I've been nothing but thrilled with mine, however it's not a track car, way too heavy
    Sep 2015
    2,308
    Which springs are you running and are your arms level? With the blue GTR's up front, they would wear out in about 3-6 months and become overly compressed and shorten in length by about a half inch. This happened with 3 sets. I'm curious if this happened with yours? Rears were not as bad, but TEN-SCTE front springs fit nicely in the rear, so I switched to those pretty quick.
    In the end, going to rear GTR shocks and TEN-SCTE front springs all the way around worked out really well.
    May 2017
    331
    Do know were i can get the TEN-SCTE springs? All i can find are hot racing TEN-SCTE springs
    I assume you know lots about springs, what are some of the basic things i should know about, like thickness and ect
    Thanks
    Dec 2017
    110
    get those?
    Hpi has some shock that are used on the e-firestorm that my friend tried and it worked better than the gtr shocks
    Sep 2015
    2,308
    Thanks
    Just get springs that fit your shocks (length and diameter) and get a few of them so that you can try different combinations. They come in different rates (stiffness).
