Results 1 to 10 of 10
    Sep 2017
    145
    17 mm hubs pins don't fit ?
    Got me a set of hubs but pins that come with it don't fit my telluride , they are slightly to large anyone had any luck or mod to fit , should I drill the axle pin hole ? Or are they only good for like a Summit or ERevo ?
    Any idea ?
    Sent from my ONEPLUS A5000 using Tapatalk
    Traxxas Employee nixhex32's Avatar
    Mar 2001
    Ft Worth, tx
    504
    Those are for the big trucks like the emaxx or revo. You should have gotten 6856x.
    Slash 4x4 lcg(heavily modded), Telluride(modded)gone, TCP, Monster Buggy, Latrax SST(heavily modded), Spartan, "My Summit" pic of that posted in the gallery........and some other things.
    Sep 2017
    145
    Quote Originally Posted by nixhex32 View Post
    Ok thanks
    Sep 2016
    13
    Do you know if the 6856x kit will work with the MIP axles?
    Mar 2001
    Ft Worth, tx
    504
    Quote Originally Posted by joe419 View Post
    No idea, best bet is to call MIP and see what they say.
    Apr 2014
    Ghent, Belgium
    147
    No, the 6858x kit won't work with MIP axles.
    Traxxas stock/cvd axles use a axle pin (12mm hexes, with the 17mm hexes this is a screw) to hold the hexes onto the axles.
    MIP uses keyed axles, without a hole to put the axle pin through. (the older version MIP axles did, but this turned out to be a weak spot on the axles, so the current design has omitted the holes, in favor of a keyed design).
    You can use MIP 10115 17mm hex adapters or Hot-Racing SLF17R06 serrated 17mm hex adapters
    P4de, G.D., K.Block, K. Busch, Summit, ERBE, TRX-4
    Sep 2016
    13
    Quote Originally Posted by degake View Post
    Thanks for the useful info
    Sent from my SM-G930P using Tapatalk
    Mar 2013
    SoCal.
    752
    Hot racing WH17HT01 is what you want. They sit on top of the mip 12mm hex.
    Here is a pic, I know its a slash but I do use the adapters I mentioned.
    IG: @818sFastestRC
    Slash 4x4 138MPH
    Sep 2016
    13
    Quote Originally Posted by Miltdoggie View Post
    So does this change the offset of the wheels at all?
    *EDIT
    I see on their specs it adds 10mm if anyone else is curious.
    Feb 2002
    9,356
    it will add width to your setup, but whatever ofset you have on your wheels is on your wheels
    I have the +6mm version the HR setup is sweet. I run the MIPs with the keyed 12mm hexes and use the 17mm conversion on my slash lcg 4x4
