    Sep 2017
    2970 EZ-Peak Charger
    I am pretty green to the Electrics and wanted to know, can you use this charger with other batteries other then the Traxxas ? I know there are batteries that are higher output then the Traxxas but these chargers seem great by taking all the guess work out of charging LIPO's.
    I got my son a VXL years ago when they were new and the charger was something that you needed to do a lot of math to keep the batteries in tip top shape and not blow up.
    I'm a Nitro junkie but going to get a VXL at some point.
    Thanks
    15,599
    My easypeak live will charge my smc packs, but i must use the app to do it. My charger will not charge non id packs without the bluetooth app.
    Ya can't polish fertilizer...
    RC Champion lektro's Avatar
    Nov 2016
    Virginia Beach/ South USA !
    1,922
    Although this is an old thread. I will give some input! Yes it can. Lipo and nimh. It has balance ports on the front. Plug the battery in along with the balance connector, press the two bottom buttons at the same time until you will hear a tone.You can set the amps you want to charge at or let the charger do it automatically. Finally press the start button till you hear another tone and bam, they are charging. You will hear another tone when they are done. You will need an adapter if not Traxxas connectors.
    Rag! You should not have to use your android
    Choose Life !!!
    15,599
    Just tried with my smc 4s pack... Ezpeak live charger will not do it. Maybe other trx chargers will. This model will not 8(. I must set up a battery profile in the app to get it to charge them.
    Nov 2016
    1,922
    Were you pushing the start/stop button and the charge rate button at the same time till you hear the tone? After doing so then you can select your settings then hit start to start charging. This is the way mine works when charging non ID batteries.
    I just looked yours has no charge rate select button.
    Choose Life !!!
    Nov 2016
    1,922
    I just looked at your charger. It is a bit more advanced than the ez peak dual. Now i see where you are coming from.
    Choose Life !!!
    Mar 2017
    You have to enable advanced mode in the app.
    15,599
    With I'd packs, it selects the charge rate and you can't change anything. With non I'd packs you make a profile In the app and and choose the charge rate in app.
