Results 1 to 13 of 13
    Aug 2013
    161
    Gearing question!
    Hello everyone, Iím going to be running the Leopard 1050KV brushless motor on 8s paired with the hobbywing max5 ESC and SMC 9200mah 90c lipos. This is in the 8s version X-Maxx. Iím not quite sure how to gear it though. Iíd like to be in the 60-70mph range. Could anyone suggest what tooth count I should run for spur gear and pinion? Thanks!!!
    Aug 2013
    161
    Thanks for the reply, That's a really cool site! I dont know what the ratio of the cush drive is however? Im sure it would make a difference.
    RC Racer Magnus001's Avatar
    Mar 2017
    British Columbia
    239
    I have a similar setup, but I only have the Traxxas batteries. I currently use a 54t spur, & 32t pinion. My motor & esc barely even get warm with that. It's got plenty of room to go taller gears if you want to.
    V1 6s w/8s conversion
    Max5 Leopard 1090kv
    Aug 2013
    161
    Quote Originally Posted by Magnus001 View Post
    Great info thank you for the reply! Thatís exactly what Iím looking for, low temps! With the gearing youíre running, Is your truck way faster than the stock 8s?
    Do you happen to know if Mod1 and Mod1.5 gears are interchangeable? Thanks!
    Mar 2017
    British Columbia
    239
    My truck is maybe 8-10 mph faster than stock, depending how straight I can keep it. It definitely has WAY more torque. I haven't played with the gearing. I bought my motor/esc combo from Kershaw Designs & just put it in, & left it. My dad has a stock 8s setup, & he's trying to get it as fast as mine, so I might have change my spur gear to a 50t soon, lol. I have no idea if mod1 & mod1.5 are similar...
    Max5 Leopard 1090kv
    Aug 2013
    161
    I wish Kershaw was still around, I canít find 8mm Mod1 pinions anywhere! Does anyone know where to get them??
    196
    I like to know to, nead some 8mm pinion.
    Aug 2013
    161
    I wonder if one could drill out a 5mm pinion to 8mm?
    Sep 2016
    117
    Quote Originally Posted by pontiacHP View Post
    Sage Custom Rc has them, Daves Motors has them, castle creations even sells them.
    de oppresso liber
    Aug 2013
    161
    Awesome thanks for the info! Greatly appreciated!
    Mar 2017
    British Columbia
    239
    I think I already know the answer, but I'll ask anyway, since I don't know for sure. Would a mod1.5 pinion work with a mod1 spur, or would it just tear it up?
    Max5 Leopard 1090kv
    Aug 2013
    161
    I wonder the same. I thought the mod1.5 is just wider than the mod1. I am unsure though.
