Page 4 of 4 FirstFirst ... 234
Results 121 to 151 of 151
  1. #121
    RC Champion lektro's Avatar
    Nov 2016
    Virginia Beach/ South USA !
    1,922
    + one to that! Very solid.....
    Choose Life !!!
  2. #122
    RC Qualifier IndyBama's Avatar
    Jun 2017
    Bama
    468
    I think part of my problem is the nyloc nut. Think it got a lil warm n melted. So wen i adjusted this last time, i used locktite on it. Havnt had a chance to run it in a few days, been workin o/t
    Sent from my SM-J327VPP using Tapatalk
  3. #123
    Nov 2016
    1,922
    I relied on mine one time and one time only, with a brand new tranny PL.. Dang nut came loose n guess you know what happened next. Well maybe you don't. Dang Spur gear stripped out on me where it slips on the yoke. Am running on lock down down now but may try 9/64ths loose...haha Mine would always have loctite on it if...................................
    I bet a good solid stainless steel nut with loctite of course, would work better than the what did you call it? Nylok I never could figure how plastic can lock a nut in place.
    Choose Life !!!
  4. #124
    Jun 2017
    Bama
    468
    Quote Originally Posted by lektro View Post
    The plastic in the nut is kinda tapered. So wen its tightened down, it gets a good grip on threads. But after on n off enuf times or it gets to warm, its no good anymore. I tightened mine all the way down n backed it of 1/16th turn. Hopefully i get off at a decent hr tomorrow n i can throw a batt in her n see how much it helped. That is if it doesnt rain...
  5. #125
    Oct 2016
    4,194
    Ring and pinion will be installed tomorrow
  6. #126
    Nov 2016
    1,922
    Been raining cats and dogs, on and off here for three days. Will be patiently waiting for the results Grip.
    Choose Life !!!
  7. #127
    Jun 2017
    Bama
    468
    Well i managed to get a short run in before the rain starts. It dun great, less than half throttle n it was pullin wheelies. Definantly gotta get metal axles lol. It pulled the joint apart at the pivot ball. Didnt rip the holes, just popped it out. But with the slipper adjusted 1/16 out from tight n the vxl r/ps, theres no clickin/grindin. Think the xl5 r/p just wasnt up for the BL power. So next upgrades for the p4de are (atleast front) axles, if not full set n the spiral r/p (front n rear)
  8. #128
    Oct 2016
    4,194
    Look at the wear on this ring gear. Iím so proud. No doubt it was the issue.
  9. #129
    Jun 2017
    Bama
    468
    Dang grip, that just shows how much fun u have lol. But does look like the guilty culprit
  10. #130
    Nov 2016
    1,922
    Dang again Bama! Grip! I thought they were 2 different animals. One for xl5 and other VXL.. Gee ma nee crickets. I would love to be fixin my diff right now with F/R new spiral r/p. Hmmm That gives me an idea. Will Order tonight....Gotta love it. Aw heck I might even put in my db while I'm at it.
    Choose Life !!!
  11. #131
    Oct 2016
    4,194
    Since the ring and pinion came to me used, I really donít know how long they lasted. Iím just gonna run the stock and see what happens. I think theyíre plenty tough. Weíll see
  12. #132
    Jun 2017
    Bama
    468
    I think the vxl r/p will help alot grip. Mine hasnt made any noise like it did before i swapped them out. I think they have a better tighter mesh, plus the teeth are a bit bigger givin more contact than the xl5s lil teeth
  13. #133
    Oct 2016
    4,194
    Quote Originally Posted by IndyBama View Post
    When I got mine it had no noise. I donít think the tooth count makes a difference. The pitch is the same.
  14. #134
    Nov 2016
    1,922
    So i have been doing a bit of research on the Helical gears. I seems that the main reason they are used in 1.1 cars is for the noise factor. Straight gears are louder, thus using them in passenger cars. Helical gears are stronger but the mesh can be a bit difficult to get exactly right and also put undo stress on the bearings due to more thrust. So the question from me would be. Do i really care about the noise factor? Not really. Do I want to replace my bearing's more often, due to the extra thrust? Not really.
    So now I am wondering if it is worth buying the Helical gears. I think I will just keep the straight unless someone can convince me that helical gears are better all the way around..... just sayin!
    Here is the vxl gear. Looks the same as the xl-5.. I could surely be wrong though... This pic was taken before i beefed it up with the e revo cup and X01 blocks.
    Choose Life !!!
  15. #135
    Oct 2016
    4,194
    I like the noise
  16. #136
    Nov 2016
    1,922
    Heard that! I am all ears on it!
    Choose Life !!!
  17. #137
    Nov 2016
    1,922
    Bama My friend! Waiting for ya to chime in on this. Trust me I am not against helical gears but would love to hear from someone that is installing them. Maybe they are worth, paying for new bearings cause heck that could be awhile before they go bad.. And maybe they won't. depending how you drive plus you never know till ya try. bearings come pretty cheap....
    Choose Life !!!
  18. #138
    Jun 2017
    Bama
    468
    Im still here brother. Im pinchin my pennies. Goina give them a shot soon. Im thinkin if i go helical, i may upgrade diff cup to aluminum lol. Idk, just sounds good. Like u said, bearings arent that expensive n theyre rather easy to change if need be. But, if the helicals cause alot of torque, would it be smart to upgrade diff house to the xo-1? I found the rear diff house for xo-1 in aluminum not to long ago... So many options...
  19. #139
    Oct 2016
    4,194
    Helical gears wonít make torque. Thatís impossible. I learned about straight cut gears for WRXís. Tranny drops, get new straight gears. Louder and stronger.
  20. #140
    Jun 2017
    Bama
    468
    The torque i was referin to was the thrust on the bearings lektro mentioned. Im still tossin the idea around in my head as to whether im goina do it or not. Sinve puttin the vxl r/p in, it hasnt made any noises. It seems alot stronger as far as the diffs go. Ive broke one stoke front n pulled the joint out of the stub on another. But i was able to put it back together lol. I need to upgrade the fronts now, but i cant find another pair of axles like i have on the rear
  21. #141
    Nov 2016
    1,922
    Thrust is a propelling force, the reaction of the applied force according to Newton's 3rd law. therefore more force against bearings. However, torque is the force that rotates an object around an axis or a fixed point. ..no force against bearings. Torque is the force responsible for rotation.
    I would say no doubt the X-01 diffs will help more so with the torque.
    Choose Life !!!
  22. #142
    Oct 2016
    4,194
    So now I have no more noise. Even doing my version of self righting. Happy camper here.
  23. #143
    Nov 2016
    1,922
    Good to hear Grip! Only noise you hear now is good noise!
    Choose Life !!!
  24. #144
    RC Racer X-Maxx's Avatar
    Aug 2017
    145
    looks like I'm gonna have to get my self a "project truck" of my own!
    6s X-Maxx-Hobbywing MAX6 8s conversion
  25. #145
    Oct 2016
    4,194
    GTRís and 60wt oil installed. Mucho bueno.
    Well used Big bores.
  26. #146
    Oct 2016
    4,194
    Got a chance to run the P4de. The GTRís are night and day better than the big bores. Dampening is so much better. Just soaks up jumps, and corners so much better. It youíre considering it, do it.
  27. #147
    Oct 2016
    4,194
    Well had my first 2075 servo failure. Had a PowerHd 13kg in it, it was not good. Swapped back to the 2075, not too many runs later the plastic gears stripped. Went with a 20kg Waterproof metal geared PowerHd.
  28. #148
    May 2017
    80
    I'd say get the savox metal gears for it (like ten bucks or so) and you'll be set but too late. Powerhd servos seem nice. My 23kg one has not had any issues.
  29. #149
    Oct 2016
    4,194
    Quote Originally Posted by CeleryMan View Post
    Good point, they can be somewhat hard though find, and in reality I didnít want to mess with them. The new servo is 23 bills to the door.
  30. #150
    Mckinney TX
    196
    Grip, sent you a PM, if you dont mind checking.
    ---Greg---
  31. #151
    Oct 2016
    4,194
    Servo installed. Also put rear springs on the front. The front sagged fully preloaded. Itís great now. Ready to bash. Servo is strong, .16 transit, so not fast but itís fast enough for this vehicle.
