Page 1 of 2 12 LastLast
Results 1 to 40 of 64
    Nov 2017
    77
    Stampede 4x4, 1st hobby grade RC
    I picked up a 4X4 stampede and 7400mah LiPo batteries and charger. What should I know about this truck to get started? What about heat? Do I need a heat sink or fan on the motor? I have a IR thermometer, what is the MAX temp I need to look for on the motot/ESC?
    Thank you.
    Also, is it OK or recommended to use dielectric grease (silicone grease) on electrical connectors?
    Oct 2016
    4,393
    160 ish should be your max temperature. Did you get the VXL? Either way you'll need aluminum shock caps. The plastic ones pop off. What voltage will you be running? Dielectric. Grease is okay. It will attract debris and is not necessary though.
    Aug 2017
    Quťbec, Canada
    91
    I think you will need to change the drive shaft for Steel ones since you will use lipo, I broke a plastic one just with a nimh battery, thats one of the weakest point of this truck
    Envoyť de mon LG-H831 en utilisant Tapatalk
    One Stampede and one TRX4
    Nov 2017
    77
    7.4V it is not VXL. I hope to upgrade to Castle 2400kv Mamba x ESC.
    Oct 2016
    4,393
    I'd encourage you to look at more brands of equipment than just one, no matter what that one is. Drive shafts will be a must with brushless power.
    For instance I run a 120amp hobbywing esc that would be perfect for that kv motor at less than half the cost. I have an MMX on my Rustler and love it, so don't get me wrong. I got it for the options and data logging for my speed runner.
    Nov 2017
    77
    Amazon has motor and esc for 220$ that seems reasonable. How do I shop a motor and esc exactly?
    I will look at more options. I plan to do a lot of upgrades before motor and esc, drive shafts, shock caps, and too lock what else I will need for a brushless upgrade. So far I know I will need a new motor mount, gear, pinion, and I assume slip clutch?
    Oct 2016
    4,393
    My clutch is fine. I use aluminum pads and carbon fiber pads. If you mean diff lock and not too lock. I wouldn't. If you enjoy the ability to turn
    Nov 2017
    77
    Meant wheel locks. So, just get some new pads when the stock pads are done? I don't want dif lock, lol. Not going to be crawling. I would like this to be a bullet proof, powerful, bashing truck for all terrain. I just don't know how to do that exactly, yet.
    anyone run the Monster Mamba MXL-6S? will that fit on this truck?
    Will this work?
    https://www.amazon.com/gp/product/B0...=ATVPDKIKX0DER
    Oct 2016
    4,393
    Quote Originally Posted by Bif24701 View Post
    Well I would move to 17mm hubs. I kept stripping the 12mm hexes no matter if I used aluminum and loctite. Not. Problem since I move to 17mm
    I'm running Tekno M6 axles and the Tekno bigbone center shaft. The motor mount can be upgraded to eliminate flex and stripped gears and ruined bearings.
    Oct 2016
    4,393
    Don't buy that esc. Get a hobbywing or MMX.
    RC Qualifier Bige4u's Avatar
    Jan 2017
    Texas
    427
    If you want a ESC/MOTOR combo that will rock your world that will drop right in, may i suggest...
    ESC - https://www.ebay.com/itm/Hobbywing-E...-/271143892179
    MOTOR - https://www.ebay.com/itm/GoolRC-3660...4383.l4275.c10
    Both max out using 4s lipo
    Bashing along @ 30mph...
    Nov 2017
    77
    That looks great, and right price. I assume I wonít need to change the spur or pinion gear?
    Ok, now Iím seeing it.
    Stampede 4X4
    Oct 2016
    4,393
    That's the combo I've got. You'll need a 5mm bore pinion.
    Here it is installed.
    I have a short video in my build thread of how it runs on 3S. 4S is a bit much for everyday tooling around.
    Oct 2016
    4,393
    Just to be clear I took out my VXL system in favor of this lower priced system. It's far more capable than the VXL stuff, and a little more than half the price.
    Nov 2017
    77
    I was just about to ask that. I’m teally excited about this now. And I already have 2s lipos, I assume will still run week and longer run time. What size (mh) 3s do you laid into the pede?
    Stampede 4X4
    Oct 2016
    4,393
    Pretty sure those are 35C 5500 mah. They're cheap batteries I use to bash with. Been good to me though
    Nov 2017
    77
    So a little back ground on getting into rc. My son has always loved quad copters but is too young to fly them well so they break or he gets frustrate. I decided and rc car or truck would be better/easier to control. The thing is he has never seen a hobby trade rc truck and what they can do. Quadcopters are all over, even flown around in malls. So as I was having a look I decided that if we both had one we could race around together. So I decided to get one for myself and gauge how he likes it, guaranteed win Iím sure but need to convince the wife not to get him a PS4. He already has everything else, XBox One & 360, PC, Nitendo 3DS, his own iPad. I think this is way better and at least get him away from those other thing for a while. So probably gethim a Skully or something like that. Itís on the Pede platform and Traxxas so we can have plenty of batteries and already bought the Dual ID. Charger. He will also like upgrading it, working on it, take apart and put together. He is 8 so I feel he is old enough to handle these.
    My Pede gets here Friday,canít wait.
    Stampede 4X4
    Aug 2017
    Quťbec, Canada
    91
    The slipper clutch spacer, buy one in alu, mine burned after only 10 days with a nimh battery
    Sep 2017
    27
    ... He already has everything else, XBox One & 360, PC, Nitendo 3DS, his own iPad. I think this is way better and at least get him away from those other thing for a while. So probably gethim a Skully or something like that. Itís on the Pede platform and Traxxas so we can have plenty of batteries and already bought the Dual ID. Charger. He will also like upgrading it, working on it, take apart and put together. He is 8 so I feel he is old enough to handle these.
    My 9 years old got his Stampede this year. Imagine how rare is to see one of these here in Poland (central Europe but still..) he loves it, even if it's only parking lot races. On weekends we're usually going to countryside and I've already build simple jumping platform there.
    You can see his first RC on top of Pede, this smal beast had same steering as big one so he had very easy learning.
    Nov 2017
    77
    I think my son will love it and we have several construction sites around here to go bashing. We live on an Air Force base in Florida.
    Stampede 4X4
    Oct 2016
    4,393
    That'll be perfect
    Nov 2017
    77
    I don’t think I’ll be getting him the Skully, a 4x4 from what I have been seeing/hearing is easier to control. I would like to get the 4x4 Slash but he will want the same kind of truck I have. Haveing two of the same will be cool for racing each other. I’ll see what his reaction is today when he sees the truck. It is on the UPS truck out for delivery.
    Pics coming!
    Stampede 4X4
    Nov 2017
    77
    Stampede arrived today. Charged my Traxxas 2s 5800mah battery on my Traxxas Dual ID charger. Seems very fast when charging one battery.
    Thoughts:
    This truck is awesome! The wife and kids are impressed, wife even said it was cool.
    Training mode is perfect for young kids learning about RC. He did well and tomorrow when I take it out to a open area I might let him reLly open it up.
    The brushed motor is still fun especially for bashing. I got wheel spin on about every surface i ran on.
    Truck is well made, this is my first hobby grade RC but I am happy with this truck.
    Stampede 4X4
    Nov 2017
    77
    Have taken the Pede out several times today, my son is haveing a great time with it. He has no problem with full speed now and drives well. The Dual Traxxas Charger is nice to charge batteries at 8 amps, charges in no time. Got dark so I took my sons LED Pelican headlamp and zip tied it to the front just behind the bumper. It’s very bright and light weight so we got two really nice bashing sessions in tonight. Loving this truck!
    Stampede 4X4
    Oct 2016
    4,393
    Good to hear
    Aug 2017
    Quťbec, Canada
    91
    Have taken the Pede out several times today, my son is haveing a great time with it. He has no problem with full speed now and drives well. The Dual Traxxas Charger is nice to charge batteries at 8 amps, charges in no time. Got dark so I took my sons LED Pelican headlamp and zip tied it to the front just behind the bumper. Itís very bright and light weight so we got two really nice bashing sessions in tonight. Loving this truck!
    Congratulation on your buy
    Have fun
    Oct 2010
    3,144
    I sent you a PM a few days ago. I hope it helps you.
    Obstacle Magnet
    Nov 2017
    77
    Quote Originally Posted by jvogel View Post
    Yes, that helps a lot. Just happens I have an IR gun so I’ll make the best use of it. Thank you!
    Stampede 4X4
    Nov 2017
    77
    So I have gone completely off the deep end and selected a few upgrades from my 4x4 Pede.
    Some items may not be clear to you so they are:
    Front and rear Slash Ultimate GTR shocks
    Blue rate springs f/b
    Blue anodized C-blocks
    SS screw kit
    And I havenít even got to the motor or tires yet but they are coming.
    I was forced to get rear axles as I broke one. Really having fun with this thing.
    My son has crossed out the PS4 in favor of a VXL 4x4 Pede for his Santa letter. I havenít told my wife what the sticker price is yet, lol. Iím thinkig other than rear axles I wonít be forced to do many upgrades to his like mine.
    I am looking at either CC 1410/3800 or 1415/2400 Mamba X Pro combo. With added weight from all of my future and current upgrades maybe the 1415 motor. But the 1410 is still awesome and donít think Iíll need to much alterations, motor should almost drop right in.
    Also upgrading to:
    TQI/TSM receiver and transmitter
    Hot Racing motor mount and Super duty slipper kit with metal spurgear
    Proline tires/wheels
    Wheelie bar
    It will be fun putting it all together but not as much as driving it.
    Stampede 4X4
    Oct 2017
    12
    Is that the RC Screwz kit? I was looking at them but I kept reading they are super easy to strip. Does anyone have any experience with them?
    Oct 2016
    4,393
    Nice. Guess you don't subscribe to the wait till it breaks then upgrade. I don't do well with that either.
    Nov 2017
    77
    Quote Originally Posted by fenixis View Post
    It is the dynamite screw kit. With the right torque and threadlock I think will be all good.
    Stampede 4X4
  33. #33
    Nov 2017
    77
    Lol, not quite. I did however break a axle, so I guess that counts right?
    All extra parts I’ll keep on hand in case they are needed for my sons truck
    Stampede 4X4
  34. #34
    Oct 2016
    4,393
    All extra parts Iíll keep on hand in case they are needed for my sons truck
    The axles are trash worthy. I've run Tekno M6's with a 2600kv in 4S. They don't seem to mind.
  35. #35
    Nov 2017
    77
    Does the VXL come with the same axles? They are junk, rest of the truck is great. What ESC are you running?
    Stampede 4X4
  36. #36
    Oct 2016
    4,393
    Hobbywing SC8-WP. It's a 120 amp esc. Program card. Very nice and it's priced right. My P4de has been a very
    Enjoyable build.
    VXL has the same axles. Out of the box the pede is pretty tough. I've been learning how to jump well with a 4wd, I haven't broken anything(bodies don't count). Then again I built this one strictly for abuse.
  37. #37
    Nov 2017
    77
    Enjoyable build.
    That’s my whole goal here, abuse the tar out of it for pure enjoyment. Also fun to take apart and put back together.
    I’m now 99% sure I’m going to go with the CC 1415 2400kv Mamba xPro combo. With all my upgrades it will have grown in weight and I would prefer to have the ability to run several 2-3s backs without heat problems or haveing to let her cool off.
    What spur gears does the VXL come with and does it have heat problems when running 2s?
    Edited for language abuse. If you see a starred out word in your post, you must edit it out to avoid earning warning points.
    Stampede 4X4
  38. #38
    Oct 2016
    4,393
    54, no it does not.
  39. #39
    Nov 2017
    77
    Lots and lots of parts in today, CC Mamba X ESC with 3800 1410 1Y 1/8 bore, Hot Racing Motor mount (this thing is pretty), got the MIP drive shafts for the front (tears already on), lots of other stuff too. Going to take me all night puttting it all in, but I enjoy that.
    Stampede 4X4
  40. #40
    Oct 2016
    4,393
    No doubt. Have a good time. Congratulations.
