After blowing out 3 sets of tires I’m curious what kind of tires everyone’s running. What would you guys Recommend sticking with the originals or is there a better upgrades
originals with 3 wraps of 50 or higher fishing line .
stock tires are fun -
these are the best tire sets I have ran on the Xmaxx's
rims used
http://www.davesmotors.com/silverbac...5b-5t-5sc.html
also use stock 5b rims
http://www.davesmotors.com/hpi-3221-...mm-x-60mm.html
http://www.davesmotors.com/hpi-3226-...mm-x-75mm.html
these tires for on road
http://www.davesmotors.com/hostile-s...i-baja-5b.html
these tires for off road
http://www.davesmotors.com/hostile-m...compound-.html
these can be found from time to time on ebay, used for a fair price
Just get out there and PLAY
fabricator
I have my stock V1 tires that I took apart, taped, re-glued, and balanced them. They run well, and I haven't had any problems with them. I also run, the new Proline wheels, and they are very nice too. If I had to pick between the two, I like the new Proline's the best. They look better than anything else out there, and they run really, really good.
I run proline badlands. I love that you don't have to glue tires and the tread compound doesnt show any signs of wear from running on pavement so far. Downside is they are a little heavy and you loose 3 mph up top! They hook up very well and don't balloon at all with 18/50 gearing on 8s.
Best wheels and tires you can get hands down are the MadMax Land G-Rippers. Proline badlands are too heavy. The MadMax are lighter, stronger, and perform better.
TRX4 Bronco
Brushless Losi 5T
Came across these the other day, expensive
https://predatorrc.com.au/traxxas-ma...th-p-5413.html
They are pricey, but I've always like that kind of tread.
Cyclone/hatchet tires are pretty cool to but I'm still looking for a set
Hopefully proline brings out some Mashers
Xmaxx 8S - Max 5 • Leopard 58113 V2
