Results 1 to 16 of 16
    Nov 2017
    Castle 1512-2650Kv
    Hi all.
    Is this motor a good choice for the Stampede 4x4? I can get it cheap, second hand from a friend.
    I will sell the Velineon set.
    Im looking for more power, speed and torque.
    RC Qualifier Bige4u's Avatar
    Jan 2017
    Texas
    421
    Its an 1/8th scale motor, so if its power you want, power you shall get.
    Just make sure its a legit one, too many clones being sold to unsuspecting buyers or that that cheap buy is exactly what you'll get.
    Bashing along @ 30mph...
    RC Racer MindBlown's Avatar
    Nov 2016
    H-town, Texas
    166
    If you have the money, I would definitely get that.
    Just be prepared for stripped gears and broken diffs and driveshafts. Also make sure to run it on 3s, because 2s isn't enough for that motor at all.
    MERV, Rustler 72mph
    @kbedrich - Thingiverse
    RC Racer GotNoRice's Avatar
    Northern California
    144
    I would consider the 1415 2400kv motor. It requires less modification to fit in to the Stampede 4x4, and is just as powerful as the 1512. The 1415 has more in common with the 1515.
    Oct 2016
    1,978
    Quote Originally Posted by GotNoRice View Post
    Same power? You sure. The 2400 is not rated to push around vehicles as heavy as the 2650 can. I'm just thinking out loud though. Not saying that either is not overkill
    RC Racer Iansprouse1's Avatar
    Dec 2016
    My Garage
    149
    Quote Originally Posted by Gripdog7205 View Post
    Iíve only had good experiences with the 2400. In my p4de Iíve hit almost 80 with this motor and temps are low. Have some mod 1 gears on the way
    Slash 4x4, Stampede 4x4, SCX10, Bearded Dragon
    Oct 2016
    1,978
    Quote Originally Posted by Iansprouse1 View Post
    I'm in no way saying it's not sweet. Just not as powerful as the 2650. My pede gets unruly at 45. But it's an MT. Got the Rustler for a speed fix.
    Sep 2017
    76
    I'm running a 4300kv 550 in mine and it flies on 2s ...on 3s it's nuts ...also temperature is way below 140F on motor running 11/54 gearing .
    Sent from my ONEPLUS A5000 using Tapatalk
    Oct 2016
    1,978
    I'm running 3660 2600kv. Fast on 3S and nuts on 4. I personally don't see a need for anything more..........yet
    Rotterdam, Netherlands
    8,522
    The 2650 is more powerful than the 2400. Not a huge difference, but it's definitely more powerful, I'd say about 20%. The 2400 is strong enough to make your Pede reach crazy speeds. The 2650 just makes it reach even more crazy speeds
    Nov 2017
    39
    Personnelly I am looking to get the CC Mamba X Pro and 1410 3800 combo for my Pede. Should be more than enough power for bashing around.
    Stampede 4X4
    Oct 2016
    1,978
    Quote Originally Posted by Bif24701 View Post
    If you run more than 2S it'll get hot. I went with a lower kv motor. More torque, and voltage and gearing options.
    Dec 2016
    My Garage
    149
    My pede is a backslash truggy conversion. It is lowered and has many many mods. It handles very well even at high speeds.
    Sep 2017
    76
    11/54 on 3s now running hobbywing SC8 ESC and 4300kv 550 and after bashing in the rain with electronic cover , fan on motor I was not even hitting 100F on motor ,ESC was at 104F so I could easily gear up but as it is it's stupid fast.
    True lower kv less heat but I have not have any issues as of yet .
    Oct 2016
    1,978
    Quote Originally Posted by Exiwolfman View Post
    Cool. Glad to hear it. Probably pretty fast how it is now.
    RC Qualifier czlynx's Avatar
    Jan 2016
    393
    Quote Originally Posted by tdv22 View Post
    Hi all.
    Yes, this is a good motor. You'll need to grind down the chassis in a few spots to make it fit. You'll likely also need to get creative with mounting the ESC as this motor is longer than stock.
