    Nov 2013
    Ohio
    697
    stock battery question
    I have been cycling my four batteries now on a monthly basis to keep them in good working order. I haven't been able to fly much at all this year due to personal responsibilities. I basically had to back out of the hobby, helicopters included, to help out while my parents recover from illnesses.
    I cycled my 4000mah batteries last night, they were fine. when I went to cycle my original 3000mah batteries, one cycled fine, but the original 3000ah battery that came with the Aton would not. this is the one that was puffed a little out of the box and came with the Aton, but always worked fine. it doesn't seem to be any more puffed then it was, but when I hooked it up to my EZ peak dual charger and pushed the start button to charge it... the red 4A light only came on and the charger gives a single tone and the light flashes? I checked the battery using my lipo battery meter and it is completely dead. I am guessing it has gone bad?
    I considered trying to charge it using my thunder pro charger, but without a balance plug, I am not sure it would be wise or safe to try it? even if I were able to "kick start" it that way, would it even be safe or reliable to fly?
    should I just dispose of it?
    thanks
    Fly fast, Fly hard, and forget about the outcome.
    Jun 2007
    Farmingville, NY
    682
    what does the voltage read?
    Traxxas please sell kits!
    Nov 2013
    Ohio
    697
    I doesn't read any voltage at all... It is completely dead. I know my meter works, because I used it to check the other three, and it read them fine. Never had a battery go completely dead like this. It kinda caught me off guard.
    Feb 2016
    913
    I've "bumped started " my Black and Decker 20v lipo battery's with success before ..
    Nov 2013
    Ohio
    697
    Quote Originally Posted by hemidoo View Post
    I have done this before on batteries that had weak or questionable cells, and was able to revive them. I've never pulled out a battery that went completely dead in all cells. I checked it on my other charger and it immediately gave a low voltage warning, so I am not going to risk it. I have three other batteries to fly with and will just have to cycle them on a bi-weekly basis rather than monthly.
