    Nov 2017
    New Jersey
    10
    I want more clearance on my Bandit VXL.... any suggestions?
    Hey there guys I was looking for a bit more clearance on my Bandit VXL and was wondering if anyone has done a conversion to a rustler recently? Ive looked around a bit but most of the posts ive found regarding conversions are fairly old and i just wanted to make sure im doing it correctly... thanks for any thoughts guys!!
    ps- i know its a diff topic but just got me an Aton the other day and holy smokes is that thing fun!!!
    RC Qualifier broitsseth's Avatar
    Feb 2017
    wherever i decide to be
    433
    do you mean ground clearance?
    if so you could just tighten the springs and/or change the mounting positions to increase ride hight but if your still wanting to do the conversion then... not quite sure
    cool ain't cheap -Dan Dreger
    Nov 2017
    New Jersey
    10
    yeah ground clearance... wanted to just get it up where i can run from concrete to grassy areas without it bottoming out...
    was thinking about maybe just putting the bigger tires all around but idk then i hear you gotta adjust the pinion and all that and thatll be me biting off more than i wanna chew lol
    Oct 2016
    4,284
    Quote Originally Posted by Coons81 View Post
    To swap a pinion, take the gear cover off(2 screws) and remove the pinion(1 screw). I have faith you can do it. Changing the suspension geometry should also be easy and it'll get you the result you want.
