Results 1 to 18 of 18
    Mar 2016
    18
    Another newbie with gearing questions
    Hello fellow X-Maxxers! I have searched this forum and 99% of the time, I can find answers. However I am confused as to what to do for my X-Maxx. I am not even sure what to call mine, (V1,V2 or 8s?)
    My truck was a V1, (I think) It used to be a 6s, but I ordered the hop up kit from Traxxas. So I eliminated the slipper clutch, and now have the cush drive. Stock ESC and the original motor that came with it a couple years ago.
    I have read that the stock gearing is 18/54. However a lot of people suggest a 22/46 ratio. However when I search online for the new pinion and spur gear, nobody has these parts. Everywhere I look, the parts are back ordered. (Must be the hot ticket!)
    So, my question is: "Where the heck do you order this 22/46 gear set from?" I have not even fired it up yet after the 8s conversion kit was installed. I found a 46 tooth metal spur gear, but I think it was the slipper clutch, didn't look quite right on the screen. Are they the same spur gear?
    RC Racer Magnus001's Avatar
    Mar 2017
    British Columbia
    228
    V1 6s w/8s conversion
    Max5 Leopard 1090kv
    Mar 2016
    524
    Tra6448x is the 8s 46t steel spur
    fabricator
    Mar 2016
    18
    Thank you for the help. I placed the order with Amain. So.. Plastic is okay? I just replaced a plastic spur gear with the metal gear that came with the hop up kit. So looks like plastic is back? Fine by me if it will hold up.
    Mar 2017
    British Columbia
    228
    $2.99 vs. $16.75 for metal. I'd rather replace 5 plastic ones. I haven't had any issues with the plastic myself. Just DON'T use the pin system to set the mesh, & you should be fine.
    Max5 Leopard 1090kv
    Mar 2016
    18
    Quote Originally Posted by Magnus001 View Post
    Okay, thank you. I agree... I like the idea of plastic because it would work like a fuse. I just don't want to be replacing fuses every time I run it. (even if they're cheap,quick and easy)
    I will run the plastic gear and see how long it lasts, I too assumed the truck was too heavy and powerful for plastic gears. But then again it had plastic in it from day one. I thought the slipper clutch is what kept that plastic gear alive, but perhaps the cush drive will do the same job?
    The pins are in it now and it did seem too tight. I will remove them and adjust it myself.
    Thanks again for the advice.
    14,936
    Quote Originally Posted by Bluelightning2 View Post
    Don’t know why you would want to use plastic on such a high powered truck
    Yep.....+1
    Ya can't polish fertilizer...
    United Kingdom
    874
    Yep.....+1
    For the exact reason stated. Plastic is durable and cheap. There is no need for a metal spur....And they are noisier.
    Oct 2017
    254
    Quick question guys.
    On my 6s, I have currently 15/54
    I ordered the 18T , 6491X but it does not fit on my xmaxx, it looks like the tooth are longer than the 15T I have. In fact, the diameter is not the same... I took the wrong part ?
    Mar 2016
    524
    That’s the rite gear
    fabricator
    Mar 2017
    British Columbia
    228
    I use the plastic spur gear because "if" it fails, it's much cheaper to replace. As I said, I've yet to have to replace the plastic one. I had the metal one in there for one run... I took it out, because the plastic one is much quieter.
    Max5 Leopard 1090kv
    Oct 2017
    254
    Quote Originally Posted by zeflex View Post
    Sorry I miss to remove the motor before ...
    14,936
    Wow. Didnt think the plastic spur would hold up to 8s. Glad to hear it does so well for you magnus 8)
