    Aug 2016
    11
    Rear wheels not turning
    Haven't used my Stampede VXL 4x4 in awhile, dusted her off and there is no power going to the rear wheels. Only the front wheels are turning when I press the throttle. I have tried to adjust the slipper clutch, negative results, and have opened the rear end, nothing looks out of place. I feel like it must be something to do with the clutch. Any help is greatly appreciated.
    RC Qualifier Iansprouse1's Avatar
    Dec 2016
    Asheville NC
    441
    If your front wheels are turning, you can rule out a broken driveshaft because the motor is in the rear and your slipper shaft goes directly into your rear diffs. Your wheel hexes could be stripped or your rear diff could be blown.
    Slash 4x4, Stampede 4x4, SCX10, Bearded Dragon
    Dec 2016
    Burleson, Texas
    269
    Rear axles are both ok?
    Scott
    Slash 2wd
    Slash Ultimate 4wd
    Stampede 4wd
    Eastern WA / Northern ID
    412
    I would inspect the rear halfshafts first, checking the inner and outer u-joints if those parts are solid I would pull the diff cover and see if the gears in there are good.
    Brushless RiPs Nitro Drips.
