Thread: E-Slayer
    Aug 2015
    575
    E-Slayer
    I recently have been upgrading my electric converted Slayer I built about 3 years ago. I used the Techno kit with a Mamba Monster 2/2650 kv motor. I somehow reused the clutch bell but recently decided to get rid of it and moved the motor forward to line up a pinion with the spur gear. I have a 17t and 18t pinion but I was thinking of putting some 2.8" Badlands on it. Considering the larger diameter tires I was thinking of going with an 11t pinion. I mostly plan on running on an indoor track in the Rockford Il area so I'm not looking for speed. What would some of you recommend?
    Sent from my SM-S975L using Tapatalk
    Jun 2015
    Brossard, QC
    1,211
    Verify with your track they allow Badlands. These tires are known for destroying dirt trscks
    Sent from my SM-G930W8 using Tapatalk
    Aug 2015
    575
    Quote Originally Posted by IllusionX View Post
    I won't be running my Slayer there, indoor, electric only. I could run my E Slayer with sct tires but I have to see if it is within R.O.A.R. specs. Otherwise break out the Slashes!!! I have a 2wd with the protrac kit I'm hoping isn't too wide. Gotta measure it after I convert their metric measurements. I'm hoping they let me run the "illegals" during open practice.
    May 2018
    3
    Quote Originally Posted by dgechrgr469 View Post
    Hi bud would you mind showing how you converted your slayer to electric? I just got one free but minus engine and it's all seized up after a dip in the north sea.
    Sent from my SM-G935F using Tapatalk
    Aug 2015
    575
    Quote Originally Posted by 1959landy View Post
    I purchased all the parts off ebay. Some of the parts are getting hard to find. There are a couple companies that make the motor mount to reuse the existing motor mount and I believe it's a Techno part for the battery tray. I'll look at it and find out for sure.
    13,889
    The other option is to buy an E-Revo chassis and transmission and swap everything else over.
    Sep 2018
    15
    Integy makes a electric kit for the slayer. It's under revo slayer section
