Results 1 to 2 of 2
    May 2017
    San Antonio Texas
    24
    1/8th conversion?
    Is it possible to do a 1/8 conversion without changing the chassis?
    I modified my rear a-arm to fit my Arrma Typhon wheel hub but the camber link was to long probably if I tune it, it could fit the shock tower then the next problem will be the differential output cups going in the rear diff. IDK if I need to get a bigger diff, which means I can't convert or there is 1/10 diffs that accepts diff cups for the dogbones like the 4tec 2.0 Or just get the Pro-line MT 4x4
    RC Qualifier IndyBama's Avatar
    Jun 2017
    Bama
    468
    Quote Originally Posted by TxBigmac View Post
    Im not sure about the whole 1/8 conversion, but i know the diffs are interchangable. Im buildin my p4de from ground up. Thought i had my diffs already, but i was wrong. I was goina use the diffs from my parts revo, but the output yokes are to big for my p4de cvds. But the revo diff outputs may work for wat your goin for. Hope i was any help for u
    Sent from my SM-J327VPP using Tapatalk
