Results 1 to 18 of 18
    Jan 2018
    USA
    19
    Exclamation Help, Stampede Problems
    So I just installed a Castle Creations SV3 combo into my Stampede 2wD and it has been working fine except for this problem: no matter how much I tighten and adjust the pinion and spur, every time I accelerate, the pinion strips out the spur from not gripping it correctly(The pinion and Spur are stock). Also when I was running the Pede, the wheel nut melted into the rim plastic and now i cannot get the nut out, please help. Im trying not to damage the driveshafts because I just got some MIPS and I dont want to ruin them. I think these problems above are why the esc overheats, im running a 5200 mah nimh battery. Thank You
    RC Champion lektro's Avatar
    Nov 2016
    Virginia Beach/ South USA !
    1,922
    Maybe the gear mesh was not set properly is what it sounds like to me. Did you use loctite on the motor screws when you installed it. the motor could have moved also. Any screw, nut that is metal to metal needs loctite. If not, the noise pitch will loosen some screws. Are you saying the actual rim of the tire and nut are fused together?
    If that's the case the only thing to loosen that is the very same thing that made it fuse together.... "Heat" from friction. Maybe a small torch very carefully.
    Choose Life !!!
    Jan 2018
    USA
    19
    No, I did not use Loctite on the motor screws, would that help by any chance?
    Nov 2016
    1,922
    Yes sir it would. I use blue loctite on all screws that are metal into metal. That is a general rule of all rc vehicles.Better safe than sorry. You should also let it set up for 24 hours before running. Did you get it apart? Another question, Are you familiar with how to set the gear mesh?
    Choose Life !!!
    Jan 2018
    USA
    19
    What do you mean by get it apart? And yes I am familiar with setting the gear mesh.
    RC Qualifier Trentbaby65's Avatar
    Feb 2017
    438
    When doing the gear mesh make sure the spur gear is rotated at least 360 so you can set mesh at the tightest spot. The gears may look round. They aren't.
    I never use loctite on motor screws. The motor heats up and softens the threadlock. Each to their own I guess and it can't hurt using it.
    Jan 2018
    USA
    19
    Quote Originally Posted by Trentbaby65 View Post
    Alright thanks, ill try that that might help the gear mesh setup, But I used loctite on my motor screws and it seems to be helping, I guess each motor and rc is different.
    Jan 2018
    USA
    19
    Can one of you guys also tell me how to remove a rounded out wheel nut?
    Dec 2017
    Van. Island British Columbia
    681
    Have you tried a pair of needle nosed vise grips ?
    Jan 2018
    USA
    19
    Quote Originally Posted by Rain Dawg View Post
    Yes but the hole in the wheel is to small, they are traxxas talon rear stampede wheels(2wd)
    Dec 2016
    Burleson, Texas
    170
    I would say if the nut is rounded it is time for a Dremel. It won't be pretty and you'l probably have to buy a new wheel and nut.
    Also sounds like something is not aligned correctly if stuff is getting hot enough to melt the wheel.
    Scott
    Slash 2wd
    Slash Ultimate 4wd
    Stampede 4wd
    Feb 2017
    438
    If you have a 1/4" drive socket set in imperial (not metric) maybe you can force (with a hammer) a slightly to small socket on the nut. You might wreck the socket but it's way cheaper than new wheels.
    Might want find out why the nut welded itself to the wheel. Bearings maybe?
    Jan 2018
    USA
    19
    Quote Originally Posted by Scott91370 View Post
    Would this damage the drive shafts if done correctly?
    Jan 2018
    USA
    19
    Smile
    Sounds like a good idea, ill try that
    Feb 2017
    438
    Quote Originally Posted by munecob12 View Post
    Quite possibly.
    I would only get out the dremel as an absolute last resort.
    Jan 2018
    USA
    19
    Quote Originally Posted by lektro View Post
    Hmm sounds like it could work, ill try the torch
    Aug 2013
    Southern MS
    67
    May be easier.....better access to disassemble it as far as you can. Take the bearing carrier off the arm, with better access, you may be able to minimize damage while removing the wheel
    15,174
    Quote Originally Posted by ewalker302 View Post
    Gonna be hard to get the pin out ove the arm. Rim will be in the way.
    Ya can't polish fertilizer...
