    Nov 2017
    24
    Silicone shock oil to lubricate bearings in X-Maxx?
    I've used silicone shock oil to lubricate bearings in my helicopters. Am I correct in assuming I can use silicone shock oil to lubricate the bearings in my X-Maxx?
    kansas
    8,683
    grease and oil will attract more dirt,
    which bearings?
    Nov 2017
    24
    The wheel bearings.
    Apr 2016
    46
    I use wd40
    Sent from my iPhone using Tapatalk Pro
    15,246
    Wd40 is not a lube. There is oil designed specifically for the wheel bearings. Shock oil will lube the race well enough, but it may cause unwanted drag in the drive line....
    Ya can't polish fertilizer...
    RC Turnbuckle Jr. mwe-maxxowner's Avatar
    Feb 2004
    pageland, sc(south of monroe)
    5,723
    I've always used marine grease, and pack it much like I do the wheel bearing on a 1:1 truck.
    Sent from my Moto G (5) Plus using Tapatalk
    460, straightpipes, buried throttle, nuff said :D
    Nov 2017
    62
    I think as long as your bearing is spinning freely, that's what matter.
    As long as there is no rust and clogging, silicon oil is just as good as any. But like other said, there is bearing oil(light/med) for wheels bearing, and marine grease is also great!
    Replace it with a new one if you don't want to waste time to clean the inside if they do clog. They are like 1 dollars each online.
    Eastern Shore, Maryland
    4,131
    Electric motor high speed bearing oil for all bearings if you're racing, and marine grade grease for all bearings if you're bashing.
