Results 1 to 31 of 31
    Jan 2018
    20
    Slash 2WD with Upgraded Motor And Esc Question
    So I upgraded my slash 2wd to a castle sidewinder sct system. When I started to use it after a little bit the truck would just start to stop and the truck would stop turning then it would be normal. Now the truck cuts out the power when I drive and stops turning and if I don’t touch the remote it works again. Any suggestions on what to do!? Also the servo gets hot to the touch.
    Mar 2004
    N. Idaho... Da Sticks!
    7,634
    What were your temps on the motor, ESC and battery after installing the new system?
    What did you set the ESC's BEC voltage to?
    What did you do to ensure proper mesh between the spur and pinion?
    Jan 2018
    20
    Quote Originally Posted by Greatscott View Post
    The temp on the motor wasnít that hot. The esc has a cooling fan so itís not hot. And battery is just warm. Everything is just warm. I didnít do anything to the ESCís BEC voltage, I just installed it the way it came. I did the trick with the piece of paper to ensure proper mesh.
    RC Racer Skyline's Avatar
    May 2016
    181
    What servo are you using, Savox servos are known to be power hungry and cause brown outs.
    its not fun until something breaks
    Jan 2018
    20
    I’m using the stock Traxxas 2075 servo
    Jun 2017
    365
    What battery are you using, lipo or nimh?
    Jan 2018
    20
    Quote Originally Posted by alexsasax View Post
    traxxas lipo 2s
    Jun 2017
    365
    I would disconnect steering rods to check is there any binding. I am sure someone who have better knowledge will give you more options to try and solve your problem.
    Someone pls correct me if I wrong but servo should not be hot?
    Jan 2018
    20
    Ok thank you
    Jan 2018
    20
    But the power also cuts out then starts running.
    Jan 2018
    9
    Quote Originally Posted by TraxxasUser123 View Post
    So I upgraded my slash 2wd to a castle sidewinder sct system. When I started to use it after a little bit the truck would just start to stop and the truck would stop turning then it would be normal. Now the truck cuts out the power when I drive and stops turning and if I donít touch the remote it works again. Any suggestions on what to do!? Also the servo gets hot to the touch.
    I am having the same exact problem. I just got this slash for me and my boy for Christmas. I got the castle sidewinder sct system. I just ordered a new servo. I hope this fixes the problem.
    Jan 2018
    20
    Quote Originally Posted by Ghostdust View Post
    I was going to purchase a new servo, but then I came on this forum to get what people said on what I should do. I still donít know but, I think Iím just going to need to get a new servo. Did you get another Traxxas 2075 servo or a different one?
    Jun 2017
    365
    Thatís usually happens when you use nimh in lipo mode, voltage drops faster and lvc cut power off. But you are using lipo.
    RC Qualifier JatoTheRipper's Avatar
    Sep 2007
    PA
    820
    I really wish people would stop buying the Sidewinder combo. It's a poor ESC especially compared to modern stuff.
    Contact Castle. They will get you straightened out.
    Jan 2018
    20
    Quote Originally Posted by JatoTheRipper View Post
    But see the thing is that I bought the system off of eBay. And the purchase isn’t in my purchase history. So I’m going to contact castle because I know that it has a 1 year warranty. Thank you for your help
    Jan 2018
    20
    What system should I get then? What do you guys recommend
    Jun 2017
    365
    Imho, cc3800kv is good motor, esc is ok for 2s. People say that esc is weak for 3s bashing. So if you stick with 2s, cc sct will be ok. You can always sell your esc an get bigger one(more A)
    Jan 2018
    20
    ok I’ll look into that
    Jan 2018
    20
    Where do I look for it?
    Jun 2017
    365
    Hobbywing have nice escí for better price than castles. I donít own it but when I start searching better esc for my car, their esc will be on top of my explore
    Sep 2007
    PA
    820
    Hobbywing have nice esc’ for better price than castles. I don’t own it but when I start searching better esc for my car, their esc will be on top of my explore
    The HobbyWing stuff is much, much better than the old Castle stuff. Check here: https://www.hobbywingdirect.com/collections/sct8-sct10
    If you are going Castle do not get anything less than the Mamba X ESC. And their motors are just average for way too high of a price. My RC Gear Shop 3900kv motor absolute destorys my Castle 3800kv.
    https://www.towerhobbies.com/cgi-bin...ar---Brushless
    Jan 2018
    20
    Can I run a Mamba X with the motor I have now?
    Jun 2017
    365
    Stronger ESC is better than stronger motor.
    Jan 2018
    9
    I was going to purchase a new servo, but then I came on this forum to get what people said on what I should do. I still don’t know but, I think I’m just going to need to get a new servo. Did you get another Traxxas 2075 servo or a different one?
    I get my new spektrum s6180 servo this weekend. I will let you know how it works. This servo should be an upgrade from the traxxas.
    Jan 2018
    20
    Ok thanks. Appreciate it
    Jan 2018
    9
    New servo fixed the problem. I have only tested to make sure it's fixed. If you would like more info on the servo PM me. I hope this helped.
    Jan 2018
    20
    Ok thank you
    Jan 2018
    20
    Did this servo fit in your 2wd slash ok? Was it easy to set up?
    Jan 2018
    20
    And did your slash also cut out then start running again? Sorry for asking so many questions I just want to make sure.
    Jan 2018
    9
    Yes...I was having the exact same issues you are having. The new servo that I got doesn't fit perfect. I could only get two of the holes to align and I'm looking for a new servo saver, as the original won't work. I will keep you updated.
    Buy I would say your servo is junk
    Jan 2018
    20
    ok let me know
