    Apr 2016
    48
    Strange speed reading
    Hello
    Xmaxx 8s - in the mobile application I get strange (high) speed readings.
    Is there a way you can config it to be correct?
    Sent from my iPhone using Tapatalk Pro
    Nov 2017
    Texas
    163
    If it is getting the speed from the rpm, then double check the gear settings in the app>garage>model setup.
    My app is also reading strangely after the update, but i also just changed the motor / esc and had to do some cutting to get the portion of the gear cover with the sensor to fit. It is reading about half the speed that it should be, but i just assumed it had to do with my “custom” work.
    Maxx 8S
    Oct 2017
    303
    Or get a cheap forerunner !
