Results 1 to 15 of 15
    Apr 2001
    Queens, NY/Orlando, FL
    520
    Question about light kit.....
    Now that the light kits are finally back in stock (got the notice from Traxxas last night), I want to place an order for a full kit today
    I'm a little confused about the wiring module though
    I've read that the lights aren't controlled by the transmitter (bummer), yet the module plugs into one of the receiver channels
    What exactly is the point of this if there's no control?
    Nov 2017
    Texas
    163
    I assume just a place to plug all the individual harnesses in, otherwise you’d have several more wires to run into the receiver box.
    You can get a receiver controlled switch and and make them controlled by the radio if you wanted to. Since the trx uses all 5 channels, you’d have to get creative an y off one of the servo outs. Like: lights on when in low gear or diff locked or something like that.
    Maxx 8S
    Aug 2017
    Québec, Canada
    91
    Quote Originally Posted by 98 SNAKE EATER View Post
    The lights doesnt take that mutch power on the battery, mine are always on when my truck is on, anyway I like to see the lights on when I go crawling
    Envoyé de mon LG-H831 en utilisant Tapatalk
    One Stampede and one TRX4
    Apr 2001
    520
    Not worried about the lights draining the battery as my pack pretty much lasts hours with my style of driving, but I would definitely like to have it remotely switchable.
    I wouldn’t mind having them turn on when only in low or whenever I lock a diff if those are my only options with the stock Tx
    Jun 2004
    177
    I’m am wondering the same thing. The module plugs into the red connector off the speed controller for power and then it lowers the voltage for the led lights. But that does not explain why we need the connector plugged into the receiver. I am just guessing but I have a feeling that it is there to tell the module when the truck is turned on so that the light only turn on when you turn on the truck otherwise the lights would be on whenever the battery is plugged into the speed controller. I wonder if there was an extra channel if there would be a way to turn the lights off using that connection or is it not looking for a signal and only looking for power on the power wire?
    Jun 2004
    177
    I just went back and watched the install video again and noticed there is only one wire going to the connector off the speed controller and one wire going over to the receiver. It looks to me like the light module is getting power from the receiver and grounding to the speed controller connector that is basically just a ground connection to the battery. That doesn’t seem right to me because that would mean the lights are pulling power from the BEC and as we all have heard the Bec on the stock speed controller is already kind of weak. Can anyone else explain this to us how this thing is powered
    Apr 2001
    520
    Hmm, does anyone make a stand alone remote kit for RC lighting?
    Sumthin like this
    https://www.youtube.com/watch?v=uposkcujP8Q
    But with a small remote like this (or maybe a simple keyfob)
    RC Qualifier SummitonSlingrs's Avatar
    Feb 2016
    Salt Lake City, UT
    374
    Quote Originally Posted by Toadster25 View Post
    Yes this is why the wire is plugged into the receiver, to tell the lights to turn on/off when you turn on/off the ESC.
    My guess is it is only looking for power.
    Sla2hP4deXSummitRusty2TRX4Bigfoot#14TEC2.0Rally
    Sep 2017
    83
    The 8028 power supply is powered off the JST tap on the ESC and is switched on/off via the signal wire that plugs into the RX. I installed the 8030 light kit on one of my TRX4s and frankly I'm disappointed with it. IMO, the only thing the 8030 kit has going for it are the rock lights. The 8030 kit provides no turn signal, brake light or backup light function. However, on my #2 TRX4, I installed a MyTrickRC light kit which provides all of the above functions and actually includes six additional lights, not counting the rock lights, that the 8030 kit does not for the above functions.
    It's a rock, get over it!
    Apr 2001
    520
    Quote Originally Posted by Inspector86 View Post
    Would I be able to use the UF-7 controller to turn the 8030 lights on individually from the stock transmitter?
    Like head/trailights-rock lights-lightbar by flicking the 2-speed or locker switches?
    Nov 2017
    Texas
    163
    From a control perspective, yes. I use their dragon controller and their light bar on my Xmaxx that way (with some creative wiring from my balance port to use 3 cells for 11.1v). Remember that to use the receiver control switch, that the batteries that power the light last must share a ground with the batteries that power the receiver.
    BUT, someone else with more knowledge about the power rating of the Traxxas light kit will have to chime in and tell us how much power that the Traxxas kit will handle. I saw someone mention that the small Traxxas distribution box that comes with the light kit steps down voltage, but I’m not sure about that. Just make sure that if you use a different controller, you don’t overpower the Traxxas kit.
    Maxx 8S
    Sep 2017
    83
    The Traxxas 8028 light power supply runs directly off the battery but steps the voltage down to 3v to power the lights. The
    UF-7 is powered off the RX and in the TRX4 that is 6v which is also stepped down to 3v. You should be able to run the TRX4 lights off the UF-7 controller with just a plug change. The problem I see is that the Traxxas light kit wiring is so fine that it might be a challenge to change plugs.
    Nov 2017
    Texas
    163
    Nice. Thanks for clearing that up.
    Maxx 8S
    Feb 2003
    South Haven MN.
    392
    Do they make a Y plug for servos? You could run both of the locker servos off one channel and lights off the other locker channel.
    I DONT WANNA GROW UP!!!!
    AND YOU CAN'T MAKE ME!!!!
    MSN MESSENGER fast350x@hotmail.com aim fast350x
    Sep 2019
    23
    Guys I have a question concerning the light kit. Tonight I went to turn on the lights and as soon as I connect them to the module, they all flash for less than a second and all turn off except for the little red ones in the back amd the ora ge ones in the front?. Any ideas? is the light module fried?
