    Aug 2015
    420
    Slayer brake transmission question.
    I was hoping to shed some weight on my electric converted Slayer by eliminating the brake and all the parts that go with it. But it looks like it won't stop without it. Is there something I could do in the trans to use the motor for braking? I haven't looked at the trans parts illustration yet but there must be some sort of one way bearing that allows it to freewheel when I let up on the throttle.
    Sent from my SM-S975L using Tapatalk
    RC Qualifier Charger Man's Avatar
    Oct 2008
    Kansas
    681
    I havenít done it but my idea is you would need to somehow remove the parts in the transmission that allow the transmission to spin while idling. I did some research and someone was talking about locking the transmission in second gear with the 3 screw method.
    115 mph Heavily Moddified Slash 4x4 on 6s
    13,320
    Yes, you need to lock it in second gear. Then you can remove the mechanical brake and use the motor for reverse. There is a one way bearing in the tranny that will allow the transmission to spin one way and freewheel the other.
    Aug 2015
    420
    Ok thanks, I really didn't want to have to reinstall all that brake stuff. I was going to open it up tonight and see what I could break. LOL!
    Aug 2015
    420
    Quote Originally Posted by dgechrgr469 View Post
    I watched a couple videos on youtube on the 2nd gear lock and got it completed on two transmissions. The only thing I did was use some longer 6-32 screws, notching the inner part of the gear next to the gear with the one way bearing then put epoxy around the screws and beyween the two gears to lock everything together. It would be nice if someone made a gearset to do this. I thought about machining a hub to get rid of the one way bearing and the bearings it rides in but I'll try that when I get a spare trans. to mess with.
    13,320
    Someone did years ago - they machined a part to fit in place of the two-speed clutch. I wish I could remember his username...
