Results 1 to 28 of 28
    Feb 2018
    44
    Traxxas summit cutting out!
    I recently bought a used summit and it worked great for a while but now when I full throttle it won't move at all. If I slowly build up throttle it works fine.It also only does this in high range, not low. All the electronic are stock. Please help!
    prescott valley arizona
    371
    Batteries in good shape?
    Stampede Vxl Aton Summit
    Feb 2018
    44
    yes they are
    Sep 2009
    Victoria B.C Canada
    5,692
    Slipper clutch should be inspected
    Sent from my SM-G930W8 using Tapatalk
    Mountains cant stop me
    they have tried
    Feb 2018
    44
    Do you mean it might be too loose or to tight?
    Sep 2009
    Victoria B.C Canada
    5,692
    Quote Originally Posted by GengarMan57 View Post
    Too loose. it should squeal if it's slipping bad.
    I suggest this from the symptoms.
    Works in low.high gear works but only if you build up power.leads me to think it's over powering the slipper clutch.
    Tighten until the spring coils just touch then back off a 1/4 to 1/8 turn.fine tune from there.
    they have tried
    Feb 2018
    44
    Ill try this. Thankyou!
    RC Qualifier czlynx's Avatar
    Jan 2016
    490
    Does cut out mean that it stops moving but you're still hearing the motor running or does everything just stop?
    Feb 2018
    44
    When i give it full throttle while it is not moving it will jerk forward like an inch and then the motor will just stop. BTW sorry for not replying soon I had to sleep and go to school and all that stuff.
    Feb 2018
    44
    UPDATE: This did not work :'(
    Sep 2009
    Victoria B.C Canada
    5,692
    Has in been in dirty conditions, mud dirt etc.
    they have tried
    Feb 2018
    44
    Yes it has. I may or may not have went through a decently muddy creek a while ago
    Feb 2018
    44
    Yes I have driven it in a dirty creek
    Sep 2009
    Victoria B.C Canada
    5,692
    Motor could use a good cleaning for a start.If you get dirt and mud in there it increases resistance costing power and creating more heat.I use non chlorinated brake cleaner.
    they have tried
    Jun 2016
    Las Vegas, NV
    388
    I agree, seems like a voltage issue. Could be the motor needs a good cleaning, and maybe even the wire connectors.
    Slash Ultimate, HW XR8 SCT Pro/3660 SD-G2 4300 KV
    371
    I use Crc Qd electronic cleaner in my brushed motors and it works great.
    Sep 2009
    Victoria B.C Canada
    5,692
    Quote Originally Posted by ryan93civic View Post
    I'm kinda a cheap.lol
    The crc works really well though and is for sure safe for plastic.
    they have tried
    Feb 2018
    44
    Ok I will try this now. I hope this works! Also, would duratrax power shot be ok?
    Sep 2009
    Victoria B.C Canada
    5,692
    They are pretty much the same thing just costs more.thats why I use brake cleaner I run in wet conditions a lot.
    So I was cleaning 3 motors a couple times a week started to get expensive.
    If you run in dirty conditions your motor will be much happier with regular cleaning and lube.
    A DROP or 2 on each bushing after cleaning.there are no bearings in it so the bushings need lubrication.
    they have tried
    Feb 2018
    44
    Ok thanks!
    Feb 2018
    44
    Ok thanks!
    UPDATE: I did this. I took the SUPER cheap route - Distilled water to clean it and 3 in 1 oil to lubricate the bushings.I put it in cup and ran it slowly. I repeated this until the water was clear. I tried things out and I think it all works okay but I can't be for sure because I am waiting for a part that should come to tomorrow so I couldn't actually drive it. I will let you all know how it turns out. Thanks again for all the help!
    Sep 2009
    Victoria B.C Canada
    5,692
    Exellent
    they have tried
    Feb 2018
    44
    UPDATE #2: It seems as though the cheap route may not have been a good idea. My motor smells disgusting and it is now impossible to hit top speed. All in favor of a new motor please say "I" I guess I'll jut have to run my slash for a while even though it sucks in the snow.
    Sep 2009
    Victoria B.C Canada
    5,692
    Look into the 14.4v dewalt if you want to stay brushed.it's a hardy motor lots of torque and is robust enough to take some abuse
    Mountains can't stop me they have tried
    they have tried
    Feb 2018
    44
    I thin I'll just stick with the titan. It has plenty of torque for me and I can find them WAY cheaper than the dewalt. Also, if for some reason the new motor doesn't solve the problem, expect to see me back here
    Sep 2009
    Victoria B.C Canada
    5,692
    That's what this place is for
    they have tried
    Feb 2018
    44
    So I got the motor. I installed it. I charged my batteries and went to run it. I was hyped to have a properly working summit again. But then THE SAME THING WAS HAPPENING! I was very upset but I just kept running it. A few days later I remembered the first response to this thread and I tried out some good working nimhs. It worked perfectly then! So I wasted my money on a new motor when I need new lipos! I tried charging them today as I always do but one wouldn't charge and I looked at the error code in the charger manual. I must have ran the battery too low or something. As soon as I can I'll get a new lipo and hopefully that will fix it!
    Feb 2018
    phx az
    how does this forum work I keep try n to post questions but keep be n told I am not authorized to post I am logged in so what gives
