Results 1 to 15 of 15
    Jan 2018
    North Texas
    398
    Guess who else has diff problems in their slash 4x4
    Background story on the truck: It's a Rally converted to a Slash (SC tires, SC body, SC bumpers), It has an LCG chassis but otherwise stock.
    About a week ago I was at the track getting a few practice laps in when as I went down the straightaway I heard an incredibly loud clicking noise from my car. I pulled my car into the pits to find the center driveshaft bent. I'm not sure how that's possible because I had a chassis brace installed at the time. I immediately started tearing down the car looking for other potential problems.
    So far I've found 2 bad bearings, some grease (I'm not even sure it counts as grease anymore), and a potentially bent center shaft (the one that spur gear sits on, not the long blue center shaft). This was all from the rear diff. I am yet to take apart the front diff but I'm hoping to do that today.
    Any ideas what else the noise may be?
    Feb 2002
    9,355
    That chassis brace is most likely what caused the bend.
    Jan 2018
    North Texas
    398
    Thanks! Once I have finished putting new bearing in the diffs I will run without the brace.
    RC Qualifier spunkybob's Avatar
    May 2016
    600
    How? Geniunely, I don't understand the physics on how something that stops it from flexing causes a drive shaft to bend.
    I understand it would break the chassis or whatnot but not the drive shaft?
    Sent from my SM-G935F using Tapatalk
    Jan 2018
    North Texas
    398
    (How? Geniunely, I don't understand the physics on how something that stops it from flexing causes a drive shaft to bend.
    Sent from my SM-G935F using Tapatalk) - quote
    Personally I don't understand it either. This is the brace I'm using: https://www.vgracing.com/product/Sla...sis_Brace.html
    I understand why a brace might break the chassis or suspension but the center shaft really. It's the common advice on these forums that braces break center shafts. I'll try it
    RC Racer Sneetches's Avatar
    Nov 2014
    151
    Seems like it would be pretty weird for the brace to bend a slipper shaft, which is solid steel, before the hollow aluminum center driveshaft bent.
    Sep 2015
    2,197
    I've broken 3-4 VG chassis braces in crashes, never bent/broken any of the parts in the center drivetrain.
    youtube.com/c/RazorRCvideos
    May 2016
    600
    Quote Originally Posted by Sneetches View Post
    Still.. the drive shaft and slipper shaft are between the ends of the chassis brace so I don't see how it would be possible to bend a drive shaft because of it.
    I twisted my drive shaft on 2200kv, 3s power when a rock got stuck between it and the chassis (no idea how it didn't just break the chassis) so I upgraded to the tekno big bone and it's been amazing.
    Edit: PS, always have your slipper set correctly.
    May 2016
    600
    Hang on... I completely miss read his initial post.. I read it as the blue shaft bent... A slipper shaft bending still boggles my mind.
    I snaped mine once after a really bad landing and I could not get me head around HOW???!!!
    How did THAT break but not any of the other parts around it.
    Jan 2018
    North Texas
    398
    Quote Originally Posted by spunkybob View Post
    I think both shafts are bent. Definitely the blue shaft and possibly the slipper shaft. The spur was also worn down on one side alot.
    Last edited by Sprinkletron; 02-06-2018 at 10:54 AM. Reason: I poorly wrote the first post
    RC Qualifier Trentbaby65's Avatar
    Feb 2017
    438
    Quote Originally Posted by Sprinkletron View Post
    Bearing failure maybe. The spur worn on one side might be the clue here.
    Jan 2018
    North Texas
    398
    Yeah maybe. That's the one bearing on the back that I haven't checked yet.
    Aug 2017
    46
    Usually a bent drive shaftshaft is caused by the same thing as axle shaft breakage.
    Bent/broken shafts are normally caused by sudden resistance when under load/rpm.
    Example. Jump with motor driving all tires and one tire stops on impact = bent/broken axle.
    Say both front tires stop when under load = bent main driveshaft/broken slipper clutch shaft.
    The chassis brace only stops chassis flex, not changes in tire inertia through the driveline.
    2x 'Pede VXL 4x4, 3x Slash VXL 4x4 HCG & LCG, ERBE
    Aug 2017
    46
    That is from high speed drive shaft rpm and sudden stop of the front wheels. Plus the typical spring stress from the slipper clutch spring.
    Basically, your slipper clutch did not disengage fast enough, which overloaded the shaft and 'SNAP'!
    Jan 2018
    North Texas
    398
    Quote Originally Posted by Jarlath View Post
    I did get bumped in mid-air at the track, resulting in a cartwheel. No problems directly after the crash though, everything looked fine, so I kept running. I probably bent the blue shaft more and more as I accelerated out of the corners
    Guess who's back.
    Back again.
