Results 1 to 11 of 11
Thread: 6s lipo's
    RC Racer Killroy's Avatar
    Jul 2015
    Steadman N.C.
    204
    6s lipo's
    What single 6s lipos would fit in the UDR.
    Marshal carraig042's Avatar
    East Tennessee
    6,788
    The posted battery compartment size is 181mm x 46mm x 56mm.
    -Brett
    4wd Sportmaxx 3.3
    Nov 2016
    Atlanta, Georgia
    943
    Quote Originally Posted by carraig042 View Post
    -Brett
    You sure that’s right? Also, what’s length, what’s width, and what’s height? Thanks.
    Jun 2016
    Las Vegas, NV
    388
    I am assuming that it is 181mm (7.125") in Length, 46mm (1.81") in Height, and 56mm (2.2") in Width.
    The Height, or Width seems off, it should be double that for 2x LiPos.
    Slash Ultimate, HW XR8 SCT Pro/3660 SD-G2 4300 KV
    Oct 2014
    Vegas
    245
    Quote Originally Posted by Peeeenuuutt View Post
    You sure thatís right? Also, whatís length, whatís width, and whatís height? Thanks.
    You can read it straight from the spec sheet
    https://traxxas.com/products/landing...-desert-racer/ (scroll to bottom)
    181mm x 46mm x 56mm
    On the list of recommended batteries https://traxxas.com/products/models/...er?t=batteries
    They have a 4s 6700 mah listed
    L = 178 mm x H= 50.5 mm x W=45mm
    3s 5000 mahs are also listed (it says its recommended to use 2)
    L=155 mm x H=25 mm x W=45 mm (each), so double the height of this, and u get 50 mm
    So, im guessing the 56mm on the spec sheet, is the Max height.
    17
    So, is the 56mm battery compartment spec the total height? If so, a 28mm thick battery in theory, is the maximum size? It would really suck to get your batteries stuck inside because they swelled a little bit--then because there's no room to expand, they overheat even more and are physically damaged due to compressive forces
    It's too bad the battery compartment is so small. I'd like to use hard case.
    15,341
    If it fits a traxxas 6700, the battery compartment is pretty huge...
    Ya can't polish fertilizer...
    Aug 2017
    53
    Itís going to be a tight fit with traxxas own 3s 5000mAh batteries, 135x28,5x44.
    Weíll see...
    Oct 2014
    Vegas
    245
    Quote Originally Posted by BPee View Post
    It’s going to be a tight fit with traxxas own 3s 5000mAh batteries, 135x28,5x44.
    We’ll see...
    Amain's video, or someone else, showed that there is wiggle room with traxxas' 5000mah batteries, so might be able to get 2 hardcase in there maybe.
    edit: here at 4:50
    https://youtu.be/sucdt7HddT4?t=4m49s
    Mar 2018
    74
    2x3s 5600
    Mar 2018
    So Cal
    84
    Hard case batts will fit, as long as it’s thickness is not much more than 1”. Total thickness space for compartment is 2.2”. So 2 1” batt packs will fit. Most batts list dimensions under specs. I’ve been checking, hoping I can get 2 6700 mAh batts in that space.
