    Feb 2018
    18
    Front a-arms swap
    Hi, I would like to know how to remove the front suspension arms to put rpm ones on
    Oct 2011
    91
    Start removing some screws, rember where they go. Reassemble. If you want more in-depth then that I'll post another post.
    Sent from my SM-G955U using Tapatalk
    Jan 2018
    Madera California
    36
    Aug 2015
    787
    Quote Originally Posted by Trapperboy View Post
    Unbolt the bottom shock mount, remove the inner and outer pins and swap your new arms on and reverse the procedure. On the rears do the same thing but let the driveshaft halves telescope apart. Pretty simple once you've done it. Do one side at a time and make sure the arms go on their respective sides, they should be marked R and L.
    Sent from my SM-S975L using Tapatalk
