    Feb 2016
    Austin, TX
    291
    Rubbing with Proline tires and Tactical body....what am I missing?
    Hi Everyone,
    I recently put the Tactical body on my originally Defender chassis, and even with the body posts up front as high as possible, the front tires are rubbing on the fenders when turning hard now that I've switched to Proline Hyrax tires. Any ideas on what to do? I've never heard of trimming fenders before, and it looks like there aren't any higher body mounts. I also have the MIP 4mm extension kit installed which should have helped a little bit already.
    Thanks for any ideas!
    Jul 2013
    Pembroke, Ontario Canada
    203
    What size tires?
    Sent from my FRD-L14 using Tapatalk
    Traxxas 1/10 Summit, TRX4 Tactical
    -Marc Gill
    Mar 2004
    N. Idaho... Da Sticks!
    7,611
    Actually, the 4MM extension kit is likely what is causing your tires to rub the body when turning. With out the extenders the wheels are just outside of the wheel wells and would turn inside the body.
    Feb 2016
    Austin, TX
    291
    They are the Proline Hyrax 1.9 but they are the larger ones not the class 1 version. Not sure of exact size.
    Feb 2016
    Austin, TX
    291
    Ha. Dang. I got the extensions to help with that. Oops.
    RC Champion zedorda's Avatar
    Sep 2015
    S.E. Michigan
    1,071
    I got hung on this same thing with another RC truck. I missed the fact that hub extensions cause the wheel to move more forward and backward when turning. Did removing them fix it?
