Results 1 to 14 of 14
Thread: Amps rating bec
    RC Champion soundmaster's Avatar
    2,858
    Amps rating bec
    Anyone knows the Amps Rating of the bec of the new VXL-6s ESC of erevo 2.0 ???
    Feb 2004
    switzerland
    287
    on the e revo 2.0 model presentation site it says under "esc specs" that the bec voltage is set at 6V and a current of 10A (peak 20A).
    greets,
    rhylsadar
    Exercitatio artem paravit
    Traxxas Employee
    Aug 2013
    Dallas
    445
    Quote Originally Posted by rhylsadar View Post
    That is correct. The BEC amperage has been beefed up for the VXL-6s.
    May 2018
    3
    Quote Originally Posted by E-Maxxdude View Post
    So if I am wanting to run a HV servo (7.4v) will this run it or doo I still need a external BEC?
    Feb 2013
    Parker, CO
    1,390
    yes it will run it but only at 6v.
    I have an RC problem...
    Jan 2009
    Great Britain
    1,038
    So what amp BEC should we get?
    2wd Slash VXL, 2wd Slash 9t , E Maxx 2200kv ,Trx4
    Apr 2018
    1,017
    A 10a CC bec is all you need. I run 2 HV servos off one of them and have not issues using them at 7.4vdc.
    Jan 2009
    Great Britain
    1,038
    Thanks 222
    California
    4,902
    The receiver on their is only rated for 6v safely. I asked Traxxas support and it's what they told me. I have been wanting to utilize the 7.4v on my servos but won't because of that issue/limit. A receiver bypass adapter and the Bec is needed with a Traxxas receiver.
    Happy fun
    Living life.
    Jan 2009
    Great Britain
    1,038
    Any wiring diagrams for the bec? Two lots of batteries and a y-servo lead has gotten me all confused ��
    Dec 2017
    Van. Island British Columbia
    858
    Quote Originally Posted by crazee horse View Post
    If you need more info pm me.
    https://forums.traxxas.com/showthrea...rvos-and-tires
    Dec 2003
    Dekalb, IL
    2,511
    It depends on the servo. They aren't all the same. You should be able to read in the specs of whatever your looking at for the stall current. You want the bare minimum to be a few amps over whatever that is so your not maxing out the BEC constantly. I know some of the savox servos pull over 9 Amps (SB2290SG being one) when run at 7.4V, so while a 10A BEC is enough... more would probably last longer.
    Expert rigging at it's best!
    Apr 2019
    11
    Hi Guys, just wanted to know if it is possible for me to use two of Blue Bird BLS-H50B in the E-Revo without using a piggy back bec? BLS-H50B has a minimum rating at 6v. By the way, when you say the esc has a peak rating at 20amp, does it mean for scenarios when there is a sudden loaded movement or burst action?
    Dec 2003
    Dekalb, IL
    2,511
    Quote Originally Posted by T|tan View Post
    Why in the world would you run two of those? One is going to easily overpower even the HD servo saver spring. At 6V it's putting out 620oz-in!
