Results 1 to 22 of 22
    RC Qualifier Madtrotter1's Avatar
    Feb 2018
    Washington
    250
    SMC 2S LIPO which one will fit or other 2s lipo options
    My stampede 4x4 VXL is in the mail and I want to pick an SMC 2S LIPO. Any of you guys currently running them? The truck's not here yet went to the local hobby shop picked up the motor fan and the ESC fan and the upgraded bearing. Other upgrades will come as the truck brakes to get ready for 3s power.
    Slash 4x4 /Stampede 4x4/Skully/Rustler VXL
    Nov 2017
    Planet Earth...I think?
    541
    From what I hear, and from what I have researched, SMC is really reliable. Unfortunately I don't own any...Yet.
    $+RC+more$+friends+more$=FUN!
    YouTube: EvHexRC1
    Feb 2018
    Washington
    250
    Same thing I have my 3's battery figured out for my slash already I want to figure out a 2's battery for my new Stampede before it gets here so I can place the order for both batteries at the same time that's why I'm asking the question. I sent SMC an email but haven't heard back yet
    Dec 2017
    54
    Quote Originally Posted by Madtrotter1 View Post
    I personally don't have any of them, but I see them recommended a lot in these forums. I frequent the e revo brushless forum a lot too.
    Oct 2016
    4,393
    Only 4S and 6S. I recommend them but Id buy more than 1
    Apr 2015
    796
    I have eight SMC 2s lipos. That's all I've used for The Last 5 Years. I've never had one issue with any of them. I would get something over 6000mah so you'll have a longer run time
    Sent from my VS985 4G using Tapatalk
    RC Champion lektro's Avatar
    Nov 2016
    Virginia Beach/ South USA !
    1,922
    I do like my Traxxas batteries. All I have owned so far and the dag gone things will probably last longer than I do. So to say, if I was to try another brand. It would surely be SMC.....
    Choose Life !!!
    Dec 2003
    Dekalb, IL
    2,513
    I run the SMC 7400mah 2S packs in mine. They fit perfectly.
    https://www.smc-racing.net/index.php...product_id=126
    I have 4 of those and 4 of the 9000mah 2S packs as well as 2 of the 9500mah 2S packs. I run the larger packs in my erbe and savage flux. I haven't tried fitting the 7400's in my erbe. They will probably work, but the wires kind of come out of the side of the pack instead of the end. They work fine in my 4x4 stampede, converted jato and savage though.
    Expert rigging at it's best!
    Dec 2015
    St. Peters, MO
    3,453
    Batt Tray dimensions is:
    L: 142 mm
    W: 48.5 mm
    Love SMC batts! In this pic only the hard case batts pictured at bottom fit in P4de. I use Apex velcro straps on most my rigs to accommodate any height batts.
    I need just one more rc, then Im done,
    Feb 2018
    Washington
    250
    Going with True Spec Premium 7.4V 7400mAh 149 Amps/90C
    Feb 2018
    Washington
    250
    Will I need the tall battery extender?
    Dec 2015
    St. Peters, MO
    3,453
    I just remember seeing the batt extender height specs but cant remember what it was. Ill look and see if i cant find it again, but to solve that issue the velcro straps are the way to go imo. They hold batts so securely. I always seemed to loose the pin on the hold down. Lol.
    Feb 2018
    18
    I've got a gens ace 5000mah 2s 50c lipo, but I switched my connector from a traxxas to deans T. So far I like it, just barely squeezes in the battery box.
    Dec 2015
    St. Peters, MO
    3,453
    Stock batt hold down is 23mm or 25mm depending on orientation.
    With batt expansion kit youll get 29mm.
    Nov 2017
    541
    Quote Originally Posted by Briber View Post
    L: 142 mm
    W: 48.5 mm
    OMG BRIBER! That’s a lot of lipos! I’ve only got around 6 right now. Three 2s’s, one 3s, and two 1s’s. I think that’s it... Boy, having those 6 is fun, having all of those must be bliss!
    YouTube: EvHexRC1
    Dec 2003
    Dekalb, IL
    2,513
    Wish I could say. I got my stampede 4x4 vxl used, so I don't know if I have the "extender" or not. I had to add about 1/4" of dense foam to hold the 7200mah 2S packs snug in it.
    The "foam" was an old dense memory foam floor mat that I have under the towel on my workbench. Was just the right thickness.
    Feb 2018
    136
    Hmmm...
    This battery is about 26mm? 27mm?
    Battery in "Crash" with battery extender:
    From what I can see here it looks like "Crash" could take something up to a good 37mm give or take.
    Dec 2003
    Dekalb, IL
    2,513
    I don't have that tall piece in the rear, but there is a tall post in the front. So, guessing mine is the "stock" hold down, which the SMC 7400mah 2S fits fine in and requires foam to make it tight.
    Feb 2018
    136
    This is the part I swapped in to get the taller post and black retainer (it only had a short post when I got it). Inexpensive upgrade:
    https://traxxas.com/products/parts/6727X
    Dec 2003
    Dekalb, IL
    2,513
    Quote Originally Posted by Zoodles95 View Post
    I have the tall post, use the shortest hole, but the rear block looks like it's stock.
    Dec 2015
    St. Peters, MO
    3,453
    The one with battery in it has the taller expander kit. The one sitting on wheels is stock. On the battery hold down are #'s they should say 23 on one side and 25 on the other. Thats the height with hold down in that orientation it will accommodate. The max height was from an old thread I dug up. Get the silly straps and be done lol. No need for foam filler or loose batts or to tall that hold down wont hold down. I messed with the silly expander for a bit then took outta all 3 of my P4des at the time and went to straps. Now it doesnt matter the size its strapped down nice n tight!
    Dec 2017
    54
    It seems to me the only reason you would need the tall posts is if you run that Traxxas 10,000 mah battery. I have seen a few aftermarket batteries that also require it.
