Page 12 of 13 FirstFirst ... 210111213 LastLast
Results 441 to 480 of 483
  1. #441
    RC Champion akrimmel's Avatar
    SAINT CHARLES, MO
    2,568
    More upgrades have come
    Sent from my SM-G935T using Tapatalk
    U.D.R. IN FULL MOD MODE
    MMX SUMMIT 2200KV!
  2. #442
    SAINT CHARLES, MO
    2,568
    More pics of them installed.
    MMX SUMMIT 2200KV!
  3. #443
    SAINT CHARLES, MO
    2,568
    Front and rear anti sway bar kit, pics and installation.
    MMX SUMMIT 2200KV!
  4. #444
    SAINT CHARLES, MO
    2,568
    Brake calipers, rear bumper and mudflats with upgraded hardware.
    MMX SUMMIT 2200KV!
  5. #445
    Apr 2003
    Smithfeild , NC
    149
    I was able to run my rig today , half way thru the battery - snapped a front axle with the Vitavon aluminum wheels on it . replaced axle and then using the Kyosho wheels and tires . They hook up better than stock , but as someone had mentioned , they strip pretty easily ! Solution : glue the wheel to the brake rotor / hub = no more problems !!!!
    Xmaxx , XO - 1 , Slayer Pro , UDR , E-Revo
  6. #446
    Nov 2016
    26
    Quote Originally Posted by akrimmel View Post
    Do you satisfied with new sway bar? Mine has been broken, so I want to install gpm sway bar too.
  7. #447
    Feb 2019
    31
    The stock rear sway bay does nothing, the front does barely anything at all. I'm curious to how this GPM sway bar kit improves the trucks handling.
    Then again, simply running it on 4S has made a noticeable difference to the handling.
  8. #448
    Nov 2016
    26
    I broke the front sway bar and the car began to roll over while cornering almost every corner especially on pavement.
  9. #449
    Jul 2018
    341
    Wow, lot of upgrades! Looks good....like the mud flaps
  10. #450
    Feb 2019
    31
    Finally fitted aluminium trailing arms, though I hadn't broken a plastic one yet but one side is bending and slowly getting worse.
  11. #451
    May 2019
    Broke the front right lower a arm jumping off a 5 foot dock. Day two of having the beast. 6s makes it dance on the line of catastrophic failure, luckily its engineered with break points. I've considered AL replacements but I'm afraid they will just transfer the force to something else that will be more expensive to fix.
    Diffs are growling. I love the sound but I'm sure it needs more grease in the boxes. Also adjusted the shocks, was belly smacking on low jumps. Oh and repainted the body
    Installed the light kit yesterday and an OBA system today (I need a batt to power it though, 3.3v I believe).
  12. #452
    Muskegon, MI
    26
  13. #453
    Mar 2016
    1,399
    thrashing the udr's over a year now
    replaced the steering servo saver again on #2- 2nd or 3rd time now
    going to order aluminum servo saver next time
    they don't break just wear out= sloppy steering
    new front axles on both
    1 million weight diff lock in the front and rear diffs is good
    all bearings cleaned and lubed
    test it again
    fabricator
  14. #454
    Mar 2016
    1,399
    it's been 5 months without repairing the udr's
    1 of my least favorite rc's to work on , an drive
    udr's wear out parts ,maintenance needed - quicker than any other
    run something
    fabricator
  15. #455
    Nov 2016
    26
    Can anyone post a video how the upgraded front sway bar works. According to the pictures gpm sway is too thick and may be to stiff. On the other hand original front sway bar doesn't work good because it is very soft.
  16. #456
    Feb 2020
    I know this isn’t the right place but I’ve been online for the last 3 hours looking for info until I made this account to make this post but I just recently bought a udr last week On Thursday and today driving it I noticed it’s drifting off to the left when the trim is at 0 and for me to make it go somewhat straight I need to adjust the trim quite a bit to the right so with that said what can I do to fix this and would this be a servo problem
  17. #457
    Mar 2015
    299
    Yeah, this question should have been a new thread, so maybe copy and paste your question into a new thread.
    Anyway, it could be several things.
    1st: what's your TSM knob on your radio set at? Try increasing (turning clockwise) your TSM setting and that might solve your problem.
    2nd: could be an incorrectly installed servo horn. Shouldn't be that way from the factory, but mistakes happen. You'd need to remove your servo horn from the steering servo, adjust the trim knob to center and re-install the horn so that the wheels are straight. This assumes you're still running the stock (solid plastic) steering links.
    3rd: could be a faulty servo, but that is unlikely UNLESS you've crashed it hard, hitting the front wheels on something. A hard hit to the wheel can strip teeth off of the gears inside your servo, making it act funny.
    4th: anything outside of these options is above my pay grade, and will need an answer from someone else.
  18. #458
    Jun 2018
    129
    Quote Originally Posted by hypnotic View Post
    My $0.02 .. be careful with GPM parts. I have not heard good things about them and because of that, I moved to HR.
  19. #459
    Jan 2020
    10
    Hot Racing front center drive shifts on both trucks. Easy to install and nice units!!
  20. #460
    Jun 2018
    129
    I think 80% of mine is HR parts.
  21. #461
    Jun 2018
    129
    Drained and refilled all shocks. They had absolutely no rebound.
  22. #462
    Mar 2016
    1,399
    Ripped the rear axle out of the #1 udr
    Need to clean and lube the bearings
    Finally going get these rc back in action
    Shocks a mess
    Center/front drive line barely spinning
    Maintenance that have been putting off long enough
    fabricator
  23. #463
    Jun 2018
    113
    Raced a couple Arrma vehicles.....they couldn't keep up.....lol
  24. #464
    RC Racer MaxxPain's Avatar
    Aug 2007
    NorCal
    238
    Installed front and rear Hot Racing sway bars. Super easy to install. They are quite a bit stiffer the stock. I'm questioning whether the stock ones did much or anything after bench test.
    UDR, Xmaxx, Rally, Slash 4X4, TRX-4, Summit 1/16
  25. #465
    Jun 2020
    Desert SW
    102
    Just got her last night, haven't even named her yet lol
    Still waiting on a few upgrades to arrive before I'll run her 100%. For now, 4s/training mode and learning the basics of her handling Loving the Rigid body so much, even the wifey approves of it and says it's cute haha.
    Sent from my SM-G975U using Tapatalk
  26. #466
    Mar 2015
    299
    Congratulations on getting it! It's an awesome truck and I'm sure you'll enjoy it more and more over time.
  27. #467
    Jun 2020
    Desert SW
    102
    Quote Originally Posted by Fallen View Post
    Thank you! it's too pretty man! I'm thinking of getting a used UDR and drive that around and my current one will be the shelf and aluminum bling queen haha.
  28. #468
    Jun 2020
    Desert SW
    102
    I was going to wait for a few more upgrade/scale parts to arrive before I drive her...But I couldn't wait anymore so I decided to break her in!.
    Had a blast! This thing is a beast even for 4s, and 4s is plenty of power for me already. I like driving it scale and 90% of the time i was only on half throttle. 6s for me would be overkill. Also clocked her at 32mph on full send, exactly as advertised! Very happy with my purchase indeed! I thought there was going to be huge learning curve when you drive this but within 5 minutes I was drifting in the desert like a pro, Don't like TSM so I had it down, and guess what, no rollovers like you see in most youtube videos! It's manufactured scale, tuned to handle like scale, and its meant to be driven scale. scale scale scale scale scale
  29. #469
    Mar 2015
    299
    Yeah man, you hit the "scail" on the head.
    I've raced bigger, faster vehicles which were driven like bashers, and repeatedly ended up on their roofs giving the race over to me. Real off-road terrain will do that to you.
    I just plugged along, driving the truck within its limits, kept it on the wheels and finished easily ahead of the bashers.
    Sure they had moments where they got in the lead, like a smooth straight away or by sending huge jumps to flat. But they didn't win the race overall, just like out in the desert.
    Race against the desert, and you might beat the other trucks doing so. Race against the other trucks, and you'll lose to the desert.
  30. #470
    Jun 2020
    Desert SW
    102
    Bro that's deep. Im gonna turn that into a sticker and put it on my UDR's rooftop
    I love it man, wish I purchased more batteries though lol. Only had about 30 minutes of runtime and it died when I was about 1/2 mile away from my car, so I had to carry this heavy beast lol. But my batteries were also brand new. I heard after about 5 charge cycles the batteries will be on their prime?
    Now I just gotta learn how to paint the scale accessories it came with.
  31. #471
    Jun 2020
    Desert SW
    102
    Cleaning and trying to smooth out the rough texture of these parts lol. Any body else's UDR look like this after 4 runs? haha
    I'm scared that driveshaft will just snap one day. I don't bash, I'm only on stock gearing and only run 4s. Vegas terrain is harsh. You guys think aluminum parts will hold better?
  32. #472
    Aug 2020
    Quote Originally Posted by halfspeede View Post
    Ordered all the stainless screws so i can swap them out as soon as the truck arrives.
    I was considering getting these aswell what all came with the screw set?
  33. #473
    Mar 2016
    1,399
    Quote Originally Posted by CrazyXMAXX View Post
    Shocks a mess
    Bout time to finally replaced the 2 failed bearings in the rear axle
    Rear aluminum hex spun a rim- glued a plastic hex in
    Back together/ tested-
    needs a front bearing that failed replaced
    the rest cleaned and lubed
    servo saver needs replaced
    Hit the track this weekend
    fabricator
  34. #474
    Mar 2016
    1,399
    Installed hot racing aluminum steering servo saver
    No more plastic worn out unworthy waste
    Run it real good
    fabricator
  35. #475
    Mar 2020
    France Marseille
    13
    Hello, our outing today in the south of France :
    Enjoy
    Gos
    https://www.youtube.com/feed/my_videos
  36. #476
    Sep 2020
    6
    Run it real good
    After installing your Hot Racing servo saver was your steering a little bit sloppy??? After installing mine I almost took it back apart cause I thought something was loose. Come to find out Hot Racing just has crap tolerances. Before I had no wheel play and now I get at least a 1/16th of an inch from each way.
  37. #477
    Mar 2015
    299
    Another user had similar gripes about some HR parts for the front end of his UDR.
    I've found HR's stuff to be about 50 / 50. Half of the time their parts are a real upgrade which benefits performance. Half of the time it's poorly made junk dressed up in nice colors.
    Unfortunately the only way I know of to tell the difference is the hard way. Buy it, try it and hope you don't regret it.
    HR's sway bars for the UDR are nice pieces that really help the truck's performance.
  38. #478
    Mar 2016
    1,399
    Yeah a Little play on steering assembly
    No problem
    Steers way good now
    A 4s udr run at the track
    every week brings a smile
    Send it
    fabricator
  39. #479
    Mar 2020
    10
    Painted all my scale stuff.
  40. #480
    Mar 2016
    1,399
    Had a Blast launching it sloppy
    Got the Mud covered udr blues
    Nice Rainy day at the track
    Was fun cleaning
    fabricator
