Page 8 of 12 FirstFirst ... 678910 ... LastLast
Results 281 to 320 of 453
  1. #281
    May 2003
    San Diego, CA
    254
    I agree on the front bumper lights, its a pain having to pull the body out to slide over the lights.
    One really cool thing with the lights is you see how well the suspension soaks up bumps. The first time i did a full throttle run with a Proline lightbar in the windshield you barely see the light move compared to how much the suspension is working.
  2. #282
    Jul 2018
    90
    Did some "speed" runs on 4S. 34 MPH seems faster in person than it does on YouTube.
  3. #283
    Mar 2016
    833
    Beat on Traxxas toys
    Enjoyed the morning at the track
    After repairs were done on fourdub’s udr
    A Pack or 3 killed his 2nd servo
    His newest 8s Xmaxx Rocks
    #2 udr and the 6s Xmaxx lost servo function after couple runs
    Axle Noise evident on #1 UDR after a few packs- stoped running
    Sl4sh rear diff issues
    Take a beating till repairs needed
    Start to Finish
    Go Traxxas
    fabricator
  4. #284
    RC Champion fourdub's Avatar
    Jan 2016
    Colton, Inland Empire, Southern California
    1,901
    havent been posting or reading lately, kinda in a funk
    still bashing atleast once a week with crazyxmaxx.
    installed two cheapie light pods, and some rpm slash mudflaps. fox udr and blue maxx are mine.
    Sla2hvxl,pe4evxl,erevobl
    "Richard Chilson"youtube
  5. #285
    May 2003
    San Diego, CA
    254
  6. #286
    May 2003
    San Diego, CA
    254
  7. #287
    Jul 2018
    90
    Screw driver and Bic Butane... the tools of champions!
  8. #288
    May 2018
    115
    fourdub its good to see you posting again!!
    Unfortunately the Rigid UDR is done, toast, kaput! Front center driveshaft broke again... thats the 3rd one. Luckily I have an aluminum shaft handy. It showed up the day after I installed my last plastic one *** lol.
    The plan is to completely tear it down, redo the diffs, rebuild the shocks, replace broken parts, and so on and blah blah blah. I need a long list of parts but luckily I bought a Fox UDR and itll be here next week to quench my rc needs. I wish the XMAXX wasnt broken too. I may get a second one of those too for this exact reason lol.
    The worst part is that I just found this awesome spot to run the truck. Its a construction site and the water run off created a fantastic silt bed that is the PERFECT scale setting for the UDR. I should have taken pictures.
    I'm the reason why we can't have nice things!
  9. #289
    Mar 2016
    833
    Cleaned the planetary gears, on #2, then replaced the
    wore out rear axle input shaft bearing 5180A 6x13x5mm
    Found a loose bolt on lower arm/bearing carrier
    Maintenance to maintain
    fabricator
  10. #290
    May 2018
    115
    [IMG][/IMG]
    Built this today for the trucks. Ill have both UDRs and the xmaxx off the table while working on other things. Since my 2nd UDR (Fox body) will be here in a few days I ordered a few upgrades for it that I have on the Rigid that I really enjoy. Also ordered steel sway bar links and turnbuckles for both. Had to order new tires for the Rigid because 4/6 of the stock tires had gone bald to the point of tearing themselves apart.
    Looking forward in the next week or so when parts get here to really tear them apart and completely rebuild them.
  11. #291
    May 2018
    115
    2nd UDR came yesterday. its a Fox body. took it for a test drive on 4s. its practically brand new and runs like a banshee. drove it for about 5 minutes and then tore it completely apart. put 60wt/80wt in the f/r respectively so Ill see how that goes. Added aluminum brake discs and rear hub retainers. also added an aluminum front center drive shaft and steel sway bar links. Waiting on a few parts for the Rigid before I rebuild it with new shocks, axles, motor, a-arms, links... basically itll be a new truck.
  12. #292
    Mar 2016
    833
    Enjoyed Traxxas RC toys all morning
    Unlimited happiness - Xmaxx glory
    Bashing the racers
    Racing the bashers
    Do it well
    Get another
    fabricator
  13. #293
    Jul 2018
    90
    Changed the rear shock oil from 30wt to 40wt, but didn't notice much difference. Will try 50. Can anyone confirm that the UDR comes with 30wt stock?
  14. #294
    May 2003
    San Diego, CA
    254
    Quote Originally Posted by TraxxasTyro View Post
    The manual says its 30wt front and 60wt rear. I just switched to 40wt / 70wt. Doesn't seem to bottom out as easily.
  15. #295
    Jul 2018
    90
    I see that now. Guess I need to learn to read. Thanks Techo Duck!
  16. #296
    Mar 2016
    833
    30wt rear shock oil had the rear end jumpin / bouncin along
    60wt is much better
    fabricator
  17. #297
    May 2018
    10
    Cleaned and regreased the front and center differentials. Also cleaned up the cut lines around the light kit I installed last week.
  18. #298
    May 2018
    115
    Rebuilt my Fox body. Aluminum driveshaft and steel sway bar links. 60/80wt in the shocks.
    In the process of rebuilding the Rigid body with 34/47 pinion/spur, steel driveshaft and 50/70wt in the shocks. Replaced the rear axle housing and regreased. front upper and lower a-arms replaced.
  19. #299
    RC Racer MaxxPain's Avatar
    Aug 2007
    NorCal
    228
    Quote Originally Posted by ben1272 View Post
    I routed things a little differently
    Thanks Ben for the pics and info.
    Xmaxx, Rally, Slash 4X4, Summit 1/16
  20. #300
    Mar 2016
    833
    Installed a HW max6 esc in the #1 UDR
    Track time tomorrow
    Run and Run some More
    fabricator
  21. #301
    Mar 2016
    833
    Lord these 4x8x3mm #7019
    small planetary gear bearings
    need a lot of cleaning/ lube - maintenance
    Ordering supply of these high use part
    When they fail - You Will Know
    As soon as you notice a slight binding
    in the drive train -like the brakes are applied-
    best to perform rear axle maintenance
    Enjoy what you Run
    fabricator
  22. #302
    Aug 2018
    Taking my time upgrading. Very happy with this truck.
  23. #303
    Jun 2018
    63
    Yesterday, I received the new aluminum rotors (wheel hubs) and was back on the road. Today: I got the Bluetooth piece installed in the transmitter - and updated the transmitter, esc and power amplifier (light kit).
  24. #304
    Aug 2007
    NorCal
    228
    I got a few things installed this week. The Traxxas light kit I decided to use Flexible braided cable on all the wires to help protect them. The kit went in great. Looks amazing.
    I went with the DHawk Aluminum Arms and C-Hubs as I have them on my Yeti XL and haven't bent them or had any issues. They fit perfect.There is a small aluminum spacer in the kit and I assumed were it went, lower arm. I noticed the lower shocks do not use the drive stock pin, but M3 bolts. They provided Gold M3 bolts which I assume are aluminum, I did not use them. I prefer a steel M3 bolt. Also blue Lock Tight on every bolt. Everything is super smooth. No binding or any issues. Will test it this weekend.
  25. #305
    Apr 2017
    161
    Finally got to take the UDR out and shoot my new Ruger pc9. Iím not sure which one is more fun
  26. #306
    Apr 2017
    161
    Oh yeah, I also put on some hot racing limiting straps. Wasnít sure how they would hold up but so far so good
  27. #307
    Aug 2007
    NorCal
    228
    Installed the GPM Steering rack. I am looking to improve the steering feel. I noticed the new servo I put in would activate the servo saver while on the bench turning left top right. You can adjust the spring now for a tighter feel. I also installed the Hot Racing clamping servo arm. HR uses o-rings on the pillow balls to help keep the dirt out. Nice idea. Everything went in no problems.
  28. #308
    Mar 2016
    833
    Another great morning with fourdub
    and Traxxas toys at the track
    UDR and Xmaxx heaven
    Get out there and play
    Go Traxxas
    fabricator
  29. #309
    Jul 2018
    90
    I went with the DHawk Aluminum Arms ...
    They certainly look good, but alas, no adjustability. Disappointing.
  30. #310
    Aug 2007
    NorCal
    228
    I'm fine with no camber adjustment. You would just end up with a bolt that fails.
    Sent from my SM-G965U using Tapatalk
  31. #311
    Jun 2018
    88
    Quote Originally Posted by slash2018 View Post
    Oh yeah, I also put on some hot racing limiting straps. Wasn’t sure how they would hold up but so far so good
    Are the straps shorter than stock.....trying not to break driveshaft....
  32. #312
    Jun 2018
    88
    Took my UDR to the track with me saturday.....our track is 1/8 scale.....so I pulled it off after 1 laps......tires have no grip.....It's fun....just not in a track yet....lol....nothing broke....bent a screw on the front bumper.....other it drove away!
  33. #313
    Apr 2017
    161
    They are pretty close to stock. I tried to measure, they might be a mm shorter then stock.
  34. #314
    Apr 2017
    161
    Where is everyone breaking their driveshafts at? This is my second UDR and Iv never broke one. Now that I said that Iím sure it will break next.
  35. #315
    Mar 2016
    833
    Where is everyone breaking their driveshafts at? This is my second UDR and Iv never broke one. Now that I said that I’m sure it will break next.
    The pin fails after aluminum shaft wears creating wobble
    which leed to wear an failure of input shaft bearing
    and axle housing wear/failure
    Wobbling drive shaft thrashes the housing and bearing
    Beat it till it’s broken
    fabricator
  36. #316
    Mar 2016
    833
    Received a new 6s lipo today
    Kcrter power 5000mah 50C
    22.2 volts of wahoo
    Found a deal at $49
    UDR Fun
    fabricator
  37. #317
    Jun 2018
    63
    Installed Dhawk trailing arms, GPM brake pads and Hot Racing rotors.
  38. #318
    Jun 2018
    88
    Raced around the yard with me cousin who had an X-MAXX....tore up my uncle's yard a little bit.....X-MAXX is crazy on 8s.....but it was fun.....now my cousin wants a UDR too.....lol.....way too much fun.....
  39. #319
    Aug 2007
    NorCal
    228
    I decided 6s might..... be a tad much for myself and my 9 year old. So after talking to SMC, I went with there 4s 10500mah pack. I did have to remove the battery retainer TRA8525 but found the pad from my Slash 4x4 fit perfect in its place. I might modify the original bracket as it needs to be shorter to allow the pack to drop in.
  40. #320
    CT
    25
    It's hard to tell in that picture, but did you try to cut down the original plastic part at the end of the battery tray? I ran into the same problem when putting my 6s in the UDR and after a while realized there is a replacement part in the bag with the manual that allows you to run a single battery that is longer, then you can remove the other plastic part to make the tray bigger.
    Garage: 33 Cars
    Traxxas 16
    Other 17
