Page 11 of 12 FirstFirst ... 9101112 LastLast
Results 401 to 440 of 453
  1. #401
    Feb 2019
    31
    A big thanks to MaxxPain for the awesome stand!
  2. #402
    RC Racer MaxxPain's Avatar
    Aug 2007
    NorCal
    228
    Right on, You are welcome. Looks good. I left mine at work and every time someone comes walking in, they forget whatever is coming out of there mouth and gravitate to the UDR.
    Xmaxx, Rally, Slash 4X4, Summit 1/16
  3. #403
    Apr 2003
    Smithfeild , NC
    149
    I ran on 4s today …. 2 packs …. its fun on 4s but it needs 6s to get it moving fast enough to excite !!!!
    Xmaxx , XO - 1 , Slayer Pro , UDR , E-Revo
  4. #404
    Mar 2019
    7
    Hi. It feels great to be on a forum again, I hate Facebook. Today I made some smoke. Help me if you can, please.
    Installing OBA system, for power I pushed out the pins for the connector farthest forward and solder the wires of a JST connector to the Traxxas connector pins. The red wire goes to the esc the black wire jumps to the other connector. I run 2 2S batteries for 4S. Everything looked good, I plugged in the JST to the OBA system and smoke started to rise. I freaked but got it all shut off and disconnected. I was crushed. I worked different things on the rig until 6am last night, slept a bit, the got working on it again. The OBA was the last thing I needed to finish, I was super happy, and then just devastated. The black wire going from my esc to the OBA box was melted badly. Not sure if the OBA is toast.
    So what did I do wrong? I'm guessing the wires on the ESC side of the connector was a bad idea?
  5. #405
    Mar 2019
    7
  6. #406
    Mar 2016
    833
    Quote Originally Posted by JustAdam View Post
    direct short = melted wires
    test positive / negative with multi tester
    fabricator
  7. #407
    Mar 2019
    7
    Quote Originally Posted by CrazyXMAXX View Post
    I will check them. The ESC was turned on when I made the connection, not sure if that was a factor. So if there is a short, how do I find it? I just don't get why it happened.
    I guess I can't post pics. Please see the link.
    http://imgur.com/gallery/37YOZod
  8. #408
    Mar 2019
    7
    Could I just run the OBA of a 9 volt battery or other nimh. I was trying to run it off the vehicle batteries to keep it simple, I tested it with a small 3s, but I didn't want to have an extra lipo on the truck that could get damaged and catch fire.
  9. #409
    RC Champion akrimmel's Avatar
    SAINT CHARLES, MO
    2,567
    FINALLY got the FOX UDR today and opened it at the track and bashed it out of the box 3s Maxx Amps 6500mah 150C discharge. Very nose heavy over jumps, will start with removing the spares. Also 80wt, 60wt which oil should go where,all advice welcome.
    U.D.R. IN FULL MOD MODE
    MMX SUMMIT 2200KV!
  10. #410
    Sep 2018
    UK
    70
    Today I will be fitting this bad boy
  11. #411
    Nov 2016
    25
    Everybody high from Russia! I am the owner of UDR too. I have installed GPM Aluminum Motor Heat Sink With Cooling Fan. But it doesn't suit good with the rear driveshaft. Don't make my mistakes. I am not permitted to post pictures. Here is the link to the picture http://forum.rcdesign.ru/attachment....9&d=1552383450
  12. #412
    Sep 2018
    UK
    70
    Quote Originally Posted by hypnotic View Post
    Someone on FB group said the same, the Hot Racing version looks like it will fit without rubbing
  13. #413
    RC Champion fourdub's Avatar
    Jan 2016
    Colton, Inland Empire, Southern California
    1,901
    Losi sbr and traxxas udr
    Sla2hvxl,pe4evxl,erevobl
    "Richard Chilson"youtube
  14. #414
    Jan 2016
    1,901
    forgot to remove the v off the other picture.
  15. #415
    SAINT CHARLES, MO
    2,567
    Pics dont do it justice, but when the wheel comes off and flies past your truck due to a lost wheel nut when you dont have replacements plus a limiting strap bolt backed out as well and your using a 4s 9000mah for the first time and after 20 minutes the following happened
    So you go home from the park because you didn't bring the tool box, way to go.
    MMX SUMMIT 2200KV!
  16. #416
    Nov 2016
    25
    I have the same gpm cooler. Does it rub the driveshaft or not on your UDR?
  17. #417
    SAINT CHARLES, MO
    2,567
    Yep, but I'm going to leave the endbell on and take off the fan and the fan cover. Once it gets warmer I will put the fan back on without the fan cover and it will prevent aluminum on aluminum contact. You will have to install to see what i am referring too. I will do the same today or tomorrow and post pics again.
    MMX SUMMIT 2200KV!
  18. #418
    Nov 2016
    25
    Sand racing. UDR is 4s, paddles. Associated Team is 6s.
  19. #419
    Nov 2016
    25
    Quote Originally Posted by akrimmel View Post
    I will put the fan back on without the fan cover.
    I want to do the same. My gpm fan is connected with separate 12v bec. I have purchased another fan which is installed from the side of motor without cutting any holes. It will be powered from another bec. I have installed two becs, 7.4v for servo and cooling fan, 12v for another fan.
  20. #420
    SAINT CHARLES, MO
    2,567
    Do you have any pics of the above
    MMX SUMMIT 2200KV!
  21. #421
    Nov 2016
    25
    Next time when I repair my UDR I will make some more pictures. I have posted some pictures in Servo thread.
  22. #422
    SAINT CHARLES, MO
    2,567
    Sounds good, thanks.
    MMX SUMMIT 2200KV!
  23. #423
    SAINT CHARLES, MO
    2,567
    Got these sick shocks
    Installed on my dirty truck
    MMX SUMMIT 2200KV!
  24. #424
    SAINT CHARLES, MO
    2,567
    MMX SUMMIT 2200KV!
  25. #425
    SAINT CHARLES, MO
    2,567
    Aluminum steering servo, front axle carriers and rear axle C hubs, no part numbers for the steering servo or the rear axle C hubs.
    Metal front chassis protector
    A better shot of them
    Hardened front and rear driveshafts, new wheel nuts, and some NOS tanks.
    New front bumper
    Rear bumper with a slight wheelie bar
    Aluminum toe links, not sure where these are yet
    Some decals for the rebound shocks
    Antennas from RC MART, one at a time.
    MMX SUMMIT 2200KV!
  26. #426
    SAINT CHARLES, MO
    2,567
    New front axle carriers, I do have anodized calipers on the way
    Installed on both sides
    MMX SUMMIT 2200KV!
  27. #427
    SAINT CHARLES, MO
    2,567
    The rear axle C hubs as well
    MMX SUMMIT 2200KV!
  28. #428
    Jul 2018
    151
    Those parts look awesome!
  29. #429
    Jul 2018
    151
    hypnotic, nice vid. UDR for the comeback win!
  30. #430
    SAINT CHARLES, MO
    2,567
    Quote Originally Posted by ben1272 View Post
    Thanks,, The shocks have been the best addition so far, truck is more stout less sway when turning.
    MMX SUMMIT 2200KV!
  31. #431
    Apr 2019
    QUESTION,
    DROVE TODAY WITH THE 4S LIPO THINK ITS SLOW COMPARE TO THE 6S
    Gearing is still stock can anybody advise me what’s the best overall gearing for it with 4S?
    Thanks
  32. #432
    Nov 2016
    25
    Twin Cooling Fan
  33. #433
    Nov 2016
    25
    cooling fan and driveshaft
  34. #434
    Nov 2016
    25
    Pictures of the becs
  35. #435
    Nov 2016
    25
    Cooling fan with cut corner.
  36. #436
    Nov 2016
    25
    Side fan doesn't suit without this mod.
  37. #437
    SAINT CHARLES, MO
    2,567
    I only had to shave a 1/4th of what you did, have pics just haven't posted.
    MMX SUMMIT 2200KV!
  38. #438
    Nov 2016
    25
    A little bit of bashing after refilling the shocks.
  39. #439
    SAINT CHARLES, MO
    2,567
    What shock oil weights do you prefer? I run 80wt in the rebounds and 60wt in the shocks.
    MMX SUMMIT 2200KV!
  40. #440
    Nov 2016
    25
    30 front, 60 rear
