    Jan 2018
    3s Lipo Combination
    Hi,
    I have a e revo 1/16 vxl. Can i connect two batteries (1400mah, 3s lipo) in parallel, so voltage remains at 11.1v. Is it safe for the motor and esc?
    RC Qualifier IndyBama's Avatar
    Jun 2017
    Bama
    468
    That should be fine. It will give u longer run times, but shouldnt hurt anything
    Sent from my SM-J327VPP using Tapatalk
    RC Qualifier fuzion's Avatar
    Athens, Greece
    650
    it will give longer run time than one battery, yet not double, due to weight. i d probably use one at a time.
    Jan 2018
    thanks for your help. Should I change any gearing for 3s lipo? and using one at a time, is more weight on one side, does that affect turning?
    RC Champion MaXXL's Avatar
    Nov 2015
    South Florida
    1,222
    Yes to both of those questions. You might be fine keeping the current gearing but most likely not. Only temperature will tell.
    10 RCs and counting 😅
