    Apr 2016
    48
    To lube CVDs or not?
    Hello guys
    Do you lube your xmaxx cvds?
    Do you lube the bearings?
    Sent from my iPhone using Tapatalk Pro
    Oct 2016
    4,395
    I donít, because itíll just collect more debris.
    RC Racer X-Maxx's Avatar
    Aug 2017
    149
    Quote Originally Posted by ponymony View Post
    Hello guys
    i use a dry lube for the cvd and i also use it for the bearings
    6s X-Maxx-Hobbywing MAX6 8s conversion
    Apr 2016
    48
    Nice idea
    I wonder if anybody puts grease in the hubs
    Eastern Shore, Maryland
    4,174
    I repack my bearings with marine grade grease, but run my CVD's dry.
    Apr 2018
    3
    I'm in the middle of a tear down and have been considering this subject. I was thinking about dry lube in the CVDs and removing the inner seal from each wheel bearing and packing them with grease plus extra grease in between.
    4,174
    Remove both bearing side covers. If the bearing is used clean it with kerosene (if new you're good), and repack both sides of the bearing with grease or high speed bearing lube. Put the covers back on, and you're good to go.
    New bearing which comes with hardly any grease.
    Used bearing after cleaning.
    Suggested lubricants.
    Repacked bearing with marine grade grease.
    Bearing repacked, reassembled, and ready for use.
