Results 1 to 11 of 11
    Nov 2017
    108
    Any use for these wheels after getting stripped?
    Just want to make sure before I throw them out. The tire is worn down on both, I don't mind trashing it as one if you guys say there is no fixing that.
    Aug 2015
    484
    I'd try epoxying the hex in the wheel and use them on the front.
    Indianapolis
    14,242
    I have often used Super Glue Professional Liquid on wheels like that. You glue the hex in and you are good! A few times I was able to get the hex out and the rim was good as new
    Jan 2015
    holland michigan
    650
    I have epoxed the hex into the hub and run them for years before. It's worth a try
    Sent from my SM-G920P using Tapatalk
    RC. an addiction I'm proud of
    Feb 2002
    9,398
    he said his tires were already bald too though.... jsut dump them at that point
    RC Qualifier whitie_bear's Avatar
    May 2014
    AB, Canada
    354
    i epoxied, and it broke eventually ... might be toast
    Slash Ultimate Modified & Summit - Lipos ALWAYS!
    Dec 2015
    St. Peters, MO
    3,445
    The trencher tread still looks good. Can you show pic of treads? Ill take em just for the tires. Lol.
    I need just one more rc, then Im done,
    Nov 2017
    Planet Earth...I think?
    541
    if you dont want em, ill take em off your hands... pm me if you wanna give em.
    $+RC+more$+friends+more$=FUN!
    YouTube: EvHexRC1
    RC Qualifier Madtrotter1's Avatar
    Feb 2018
    Washington
    250
    Things you will need to fix
    1. 5 min Loctite Epoxy or Devcon Brand industry strength
    2. Front or rear drive shaft
    3.Hex Nut
    4. saran wrap
    Clean the the inside up real nice wrap the hex nut up in saran wrap fill the empty rim hex with 5min epoxy place hex nut in hole push the axle through hex nut as if putting tires on your truck secure with lug nut. Let empoxy set up best if over night. I have used this trick on a few set of tires and it has paid off for me. I have a YouTube Video if you need it i can look for it when i get home
    Slash 4x4 /Stampede 4x4/Skully/Rustler VXL
    Dec 2015
    St. Peters, MO
    3,445
    Quote Originally Posted by Madtrotter1 View Post
    3.Hex Nut
    4. saran wrap
    Excellent idea!
    Quote Originally Posted by EvHexRC View Post
    Hold on there speedy, I was first! Lmbo
    Feb 2018
    Washington
    250
    The MIP hex nut was chewing up the hex pattern on my father in-laws Pro-line rims. So had him leave a set with me. I have fixed 4 complete pairs of tires for him after the first pair worked out. It just takes a little time don't rush it let the Epoxy harden. The last set i did i finished it off with a coat of guerrilla glue using a fine bristle paint brush to get it on thin.
