Results 1 to 13 of 13
    8
    Turning off the VXL-6S
    Hey all,
    Absolutely loving my new UDR!! Truck runs great, but when I try to turn off the ESC by pressing down the button, the red lights cycle, and it powers back on. Every once in a while, it'll stay off, but maybe only 1 out of 10 times I try to power down. I end up having to unplug the battery (4S). Happens even when I'm not even close to LVC, so that can't be the issue.
    I did replace the TQi radio with my Futaba 4PV and a 203GF receiver, but I can't imagine that would have any impact on the esc functionality.
    Any thoughts?
    Thanks,
    John
    Traxxas Employee
    Aug 2013
    Dallas
    445
    The button is an "On" button, but not an "Off" button. To turn it off, you just unplug it. If you hold the button too long, it will enter programming mode.
    RC Champion fourdub's Avatar
    Jan 2016
    Colton, Inland Empire, Southern California
    1,901
    You should be able to turn off the truck with the "On" Button.
    Only time i cant turn the truck off is if its overheated or in LVD.
    You should be able to turn it off. Only need to push and hold for maybe 1 second.
    I ran into a problem with my vxl-8s - i got dirt and rocks inside the esc behind the power button. when i would plug a battery in, it would turn on and go into programining mode. blowing out the esc with air fixed my issue.
    (button did not make a clicking noise to indicate it was working, till i cleaned it)
    does your button "click" ok?
    Sla2hvxl,pe4evxl,erevobl
    "Richard Chilson"youtube
    8
    Quote Originally Posted by fourdub View Post
    Yep, the truck is basically brand new.
    So far the only way it turns off is if I hold the button down and count "one-one thousand, two-one thousand, three" and leg go. Then it shuts off about 50% of the time. I've only run one pack thru the truck, and didn't get close to LVC or thermal.
    Very strange...
    8
    According to the manual...
    4. The on/off switch is integrated into the speed control. With the
    transmitter on, press and release the EZ-Set button (.25 seconds).
    The LED will shine GREEN. This turns the model on. To turn the
    VXL-6s off, press and hold the EZ-Set button until the LED turns
    off (.5 seconds).
    Holding the button until the light turns off doesn't work on mine...
    Jan 2016
    1,901
    I would call traxxas and explain the situation to them.
    It should turn off right away.
    8
    Probably a good idea. Thanks!
    Sep 2018
    5
    Did you ever get this sorted out? I have the exact same issue on a brand new E-Revo..
    Mar 2016
    828
    The problem with turning any RC off with
    lipo batteries using the switch is ;
    It can be overlooked- left plugged in-
    -for weeks-
    Killing the lipo’s
    Just unplug
    fabricator
    Nov 2016
    Atlanta, Georgia
    943
    I’m surprised more people didn’t have this issue... I had it happen a lot on my e revo’s vxl 6s. Turning it off would do the rwd lights, power off, then rwd lights again, and back on. And yeah, about once every few times it’d turn off. But that esc did nuke itself later on, however I’m pretty sure those have no correlation.
    Oct 2018
    It should be able to turn off by the ez set button, it says so in manual, Traxxas will say it’s an ON only button, if they admitted it was not functioning correct, they would have to replace all of them, which is huge money for them, so it’s easier to lie and say it’s supposed to be like that, but the manual proves them wrong.
    Sierra Vista, AZ
    1,032
    Anyone ever get this figured out? My brand new E Revo 2.0 does the same thing listed above...so frustrating.
    ABMods 3.3 Revo PE
    Jato 3.3
    Futaba 3PM
    Mar 2019
    MD
    Mine used to do this and one day the button started shutting it off like the other two UDR's I run with. I didn't mind unplugging to shut down so I never complained. Seems to work as engineered since.
