Results 1 to 17 of 17
Thread: Servo winch
    May 2018
    23
    Servo winch
    Hey y'all..i got the trx4 bronco.. got a bull bumper, but a winch won't mount to the bumper without pushing it out farther, which I don't want. Looking to get an internal servo winch. any suggestions on how to do this?
    Sent from my SM-S327VL using Tapatalk
    Feb 2018
    53
    I seen a bunch of videos on YouTube on how to do this. It has me convinced to try it when I'm ready or a winch.
    To run it I'll probably go with the Warn remote controller since I don't have any extra channels on my controller.
    N. Idaho... Da Sticks!
    7,719
    There are a couple of ways to do this.
    The first thing you need is a way to mount the servo, Werty Made makes an electronics tray that mounts around the steering servo and has a spot for a servo winch to mount. The design is ok, I don't really care for the part that sits next to the motor, and it would be a lot better if it were made out of aluminum. I bought one, copied the pattern and made my own aluminum mount.
    https://www.google.com/search?ei=8Y7....0.ojp0eH8Xrx4
    There are a couple of ways to do a servo winch. Using one with the servo's internal electronics is still a pain, even when you buy one that is "professionally" modified, the servo still tends to drift. The best way I have found is to gut the internal electronics completely and just use the motor and servo gears, running it off of a 1/18 scale ESC connected to an extra channel. You can also use a Hey OK winch controller. I don't know if the RC4WD remote winch controller will handle a servo motor, and those systems are, for the most part, junk anyways.
    May 2018
    23
    So the trx4 bronco has this set up for a front battery mount. Anyone seen a replacement plate for a servo winch? If not i think I'll use a dremmel and modify it myself.
    May 2018
    23
    Not sure if i like the crawler innovations one
    RC Racer cozyFozy's Avatar
    Oct 2017
    Endless Summer, United States of America
    180
    Quote Originally Posted by browningjason78 View Post
    So the trx4 bronco has this set up for a front battery mount. Anyone seen a replacement plate for a servo winch? If not i think I'll use a dremmel and modify it myself...
    Hey man, check this one out. I think this could be what you need.
    https://www.shapeways.com/product/F9...ionId=63074774
    9.7mph 3s TRX-4 Land Rover
    Feb 2018
    53
    I liked the first video and might follow some of what he did but I'm leaning more toward the second video winch type.
    https://www.youtube.com/watch?v=h5YFlWyfnCs
    https://www.youtube.com/watch?v=IyAxpaLa-Mk
    Feb 2018
    53
    OK, I started on my servo winch and If you have the right equipment it is very easy to do. I thought the spool would be the tough part, turns out it was one of the simplest steps so far.
    Feb 2018
    53
    I made a little progress since the last picture.
    I had to start partially over and rethink a few things. I did get the shaft made, just need one more end plate and then I can wire this thing up.
    RC Qualifier JatoTheRipper's Avatar
    Sep 2007
    PA
    826
    Nice work! It must be awesome to have access to lathes and other machining tools!
    Feb 2018
    53
    Thanks,
    I'm about done but there is a few things I'd do differently net time. One thing I need to change is get some flat head 2.5mm screws to replace the two you see in the picture above. Those heads are bothering me and if I counter sink the flat heads flush it would make life easier.
    The second thing I'd do different is use smaller OD bearings.
    Third thing is I'd start with 1/4'' angle instead of bolting the front plate to the bottom one.
    Here is tonights progress.
    Sep 2007
    PA
    826
    Looks great!
    Feb 2018
    53
    I got it mostly done tonight and it seems to work great!
    https://www.youtube.com/watch?v=XAgcU8scF3Q
    7,719
    Nice work! I would have gone nuts drilling at tapping all of those 3mm holes, there is always that one that was drilled just a little off.
    Feb 2018
    53
    Thanks, The older I get the harder it is doing small things like that!
    Feb 2018
    53
    I finally took some pictures of the winch.
    This thing is a beast!
    It picks up my 10 pound TRX without a change in sound or speed. I hooked it up to a 50 pound hand cart at work and it started to lift it but I chickened out and stopped as soon as I seen it start to work hard. I don't want to break it right away before I get to use it in my next comp this Saturday.
    The 300 lbs fishing string works well and doesn't have a memory like I hear some do. The string comes out straight and winds up tight.
    I could not be happier with the outcome!
    Feb 2018
    53
    Testing the servo winch by lifting my buddys TRX. The winch hardly even changes sound when it leaves the ground!
    https://www.youtube.com/watch?v=A3b6beuJ1-4
