Results 1 to 24 of 24
    May 2016
    76
    Optional shock springs
    Can anyone tell me what the stock spring rates are front and rear? Also can someone point me to optional front and rear springs part numbers? Iíd like to stiffen up the spring rates all around. Thanks in advance!!!
    Apr 2018
    20
    +1 interested in this...
    Can I add, how to sleeve those as well ? I feel like I find nothing for a long shock like this...
    May 2016
    76
    I found optional springs for the front with different spring rates but I couldnít find anything for the rear.
    I also couldnít find information on what spring rates the stock springs are. Anyone?
    RC Qualifier MAC FAB's Avatar
    Apr 2014
    So Cal
    804
    Certainly Losi has something that would fit, right? I don't know the diameter of the UDR shocks, but HPI Savage XL springs are the right length, 6" shock with a 2 in stroke. Regular plastic shock is the same size as the standard Slash, aluminum big bores are a much larger diameter. I can measure mine when I get home. Dual rate springs, they have a few different spring rates available.
    Apr 2018
    9
    I see now available the progressive rate shock springs in traxxas site:
    8443 Spring, shock, 139mm (natural finish) (GTR) (progressive, 0.937
    rate, orange stripe) (2)
    8442 Spring, shock, 139mm (natural finish) (GTR) (progressive, 1.146
    rate, green stripe) (2)
    8441 Spring, shock, 139mm (natural finish) (GTR) (progressive, 1.250
    rate, blue stripe) (2)
    Is the blue ones the stiffest?
    Br,
    Manos
    May 2016
    76
    Nice!!! What about the rear springs?
    Oct 2014
    Vegas
    244
    Rear springs are listed also, just go to traxxas or amain's site and look them up
    https://www.amainhobbies.com/traxxas...a8445a/p746162
    Mar 2018
    So Cal
    84
    Cool!! How do you know which spring rate to choose without knowing stock spring rate?
    May 2016
    76
    Yeah those blue rear springs are just colored versions of the stock ones. I want stiffer ones.
    Oct 2014
    Vegas
    244
    Quote Originally Posted by saddlesore View Post
    where did u find the spring rate of the stock ones?
    Mar 2016
    836
    Ordered 1.25 spring rate
    fabricator
    May 2016
    76
    Quote Originally Posted by CrazyXMAXX View Post
    For the front? Or rear?
    Mar 2016
    836
    Going to try both
    To see the difference
    From the stock white strip springs
    fabricator
    Apr 2018
    20
    Keep us posted, interested to see the difference vs stock which we don't know the rates...
    They list front and rear different part numbers, but the optionnal progressive rates are not labelled front or rear so, let's figure that out. Shouldn't be that different front vs rear....maybe softer in the front
    Mar 2016
    836
    They are a little stronger than the rear stock springs
    Much stronger than stock fronts -thicker gauge steel stock
    The front suspension is fully extended with no preload
    Waiting on parts to test
    fabricator
    RC Champion fourdub's Avatar
    Jan 2016
    Colton, Inland Empire, Southern California
    1,901
    Here is crazyxmaxx's truck with the springs on it.
    Sla2hvxl,pe4evxl,erevobl
    "Richard Chilson"youtube
    Mar 2016
    836
    installed the stock rear spring on the front and the 1.25 blue strip on the rear
    It didnít dive as hard in the turn
    Trying this setup on both at track
    fabricator
    Oct 2007
    25
    How about running another set of stock springs on the bypass shocks? 4extra spring collars n your away. Might not b scale but would be a good budget upgrade
    Aug 2017
    32
    i just started messing around with the setup on the udr for track racing. and what i settled on for now with is factory setup in the rear. with the traxxas 1.5 4 hole pistons (from the 8455 rebuild kit) with blue springs and 40wt oil limited 12mm. i put a piece of 12mm long nitro fuel tubing on the shock shaft right under the shock piston to limit travel. this setup is a huge improvement over stock
    Mar 2016
    836
    #1 setup
    32/51 gears ,Green strip spring 1.14 rate on front
    Blue strip 1.25 rate on rear with 10mm limiting spacer
    #2 setup
    31/47 gears blue strip spring on rear/
    Stock rear spring on front
    with paddles hooked up at the track -
    with 10mm spacers f & r
    fabricator
    May 2016
    76
    Going to try both
    can you give me the part number for those springs please? id like to order some. thanks!
    Mar 2016
    836
    8441 are the strongest
    Travel limiters useful
    fabricator
    May 2016
    76
    oh so the springs are the same length for front and rear shocks?
    Apr 2018
    9
    It seems the progressive springs are not available yet in Europe. Does anyone know if there any other brand springs that fit the UDR?
