Results 1 to 15 of 15
    RC Racer Storm68's Avatar
    Mar 2018
    Gold Coast, Australia
    236
    Why the popping?
    Can anyone tell me why these brass inlets keep coming out of my bar ends?
    The last 2 times I've gone out for a spin now one has popped out.
    Both times were from my front camber links, one left and one right.
    The left one popped out today but after the right one popped out a couple of days ago I took a spare plastic end with the inlet just in case.
    They were originally short ends that popped over the inlets but I've replaced them with long plastic ends..
    It just seems everytime I go out now something goes wrong and my time of fun gets cut short.
    It's making an enjoyable hobby that I've spent way to much money on very unenjoyable.
    I'm lucky if I burn through one battery now and I'm always waiting for something to happen which pretty much always does.
    Sent from my SM-G955F using Tapatalk
    Feb 2018
    580
    Why the popping?
    Quote Originally Posted by Storm68 View Post
    I would try the rpm caps. I’ve had the same problem but I was able to just pop them in.
    I would love if I could get more run time than shelf time. Isn’t that what everybody’s wants? I wish
    Indianapolis
    14,614
    Can you please provide a picture of where those are from? Those don't ring a bell. I recall the longer ones, not the short.
    Feb 2018
    580
    Why the popping?
    I agree they do look strangely short. Especially if you replaced them for longer ones...
    Mar 2018
    236
    Pardon the mess, their attached to the front shock towers, lower inside holes behind the front.
    I'm using the Proline Protrac system so have the longer links being used.
    rollbars.
    Riverton Utah
    5,644
    I'd get a new set, # TRA1942. It'll come with a whole bunch of new ones, it's quite possible yours are just worn out.
    Manager at LHS ~7 Years. I've seen some stuff lol
    Mar 2018
    236
    I'll replace all the short ends with long and see if that works.
    The inlets don't go back in no matter how hard you push/hammer so their just junk now.
    Sep 2015
    2,348
    There's probably something going on with those super flexy arms and overly low ride height you're running. Move the arms through the full range of motion, from fully compressed to fully extended, and see if those camber links still have play in them and can move freely, or if they are being stressed to the point of almost popping off. Also fully twist the arms and try to bend them fore/aft to see if that also binds up the links and makes them want to pop off.
    BTW, those metal pieces are called hollow balls and the plastic pieces are called rod ends.
    youtube.com/c/RazorRCvideos
    Jul 2013
    Northern Norway
    897
    It's easy to pop them back on. I use a 7mm socket wrench (wheel nut wrench). Place the ball on a hard surface, put the rod end on top and push down on the plastic with the 7mm socket placed on top of the ball (so that the ball goes inside the socket).
    Edit: I agree with Razor, there has to be something preventing full motion. If you have a lot of droop maybe the rod ends will interfere with the collar on the MIP's - I've seen it happen when using the lower holes on the shock tower.
    Mar 2018
    236
    I'll adjust the springs and see what else I can do to raise the height.
    I read somewhere not to use the top holes on the shock posts because of the reason mentioned, interference .
    Jul 2013
    Northern Norway
    897
    It won't help adjusting the springs. To limit the droop you'll have to move the lower shock mount out to the outermost hole on the A-arms, or install a spacer on the shock shaft inside the shock (not recommended since the front shocks are short enough as they are).
    However, if the problem is binding between the MIP's and the inner camber link rod end, the easiest way is to move the camber link to the inner top hole on the shock tower (according to your picture above you have them mounted in the lower inner hole). Also, the wide flat collar on the hollow ball should face the screw head to avoid the rod end to slide completely off if it pops off the ball (can't tell for sure from the picture, but it looks like only the left side hollow ball faces the correct way).
    Hope this made any sense at all...
    Mar 2018
    236
    Thanks mate, just about to go to bed but I'll try your suggestions out in the morning.
    Thanks for the help.
    RC Champion MaXXL's Avatar
    Nov 2015
    South Florida
    1,222
    So yes def make sure your setup is not causing this issue.
    Also, these rod ends DO get worn out over time. Its just natural wear and tear. This same thing happened to my shock ends. I was able to tap the shock on the table and the ball fell out. It was VERY worn at that point lol.
    10 RCs and counting 😅
    Mar 2018
    236
    Was reading up on adjusting ride height, from what I can tell you move the top of the shock out on the shock towers and the bottom of the shock in on the A-arms to make it more upright?
    And to use bottom holes on the shock towers?
    It was actually in an old post from these forums that came up when I Google'd it.
    Also by moving the camber link up to the top hole I was told it reduces your steering turn that's why their on the bottom hole.
    Pretty sure my hobby store guy told me that one because I had them there originally.
    Mar 2018
    236
    Ok so straightened out the ride height feels a lot better.
    Just have to change the links to the top of the shock tower and done.
