Page 2 of 2 FirstFirst 12
Results 41 to 45 of 45
  1. #41
    Nov 2016
    Atlanta, Georgia
    943
    You should be looking at the volt meter function of the multimeter then. An ohm meter measures electrical resistance. I was wondering how you’d use that to determine state of charge. Ohms are the units [of resistance]. A volt meter measures electric potential difference.
    I read what you wrote. You simply used the wrong term. No need to get angry with yourself or anybody else.
    Multimeter... not ohms. Ops. Sooo let’s all be friends.
  2. #42
    Dec 2003
    Dekalb, IL
    2,270
    Curious if the OP on this thread adjusted his LVC from factory to be a bit higher. If memory serves, the factory LVC is 3.2V. Most people get the $20 program card and adjust that to 3.5V. This helps with over discharging.
    Expert rigging at it's best!
  3. #43
    Nov 2016
    Atlanta, Georgia
    943
    Quote Originally Posted by olds97_lss View Post
    My MXL 6s was also set way too low. Definitely bump it up to 3.5 minimum. It does take up a minute of run time but makes ur batts last a whole lot longer.
  4. #44
    RC Qualifier lotust251's Avatar
    Mar 2017
    Long Island NY
    280
    wait you can adjust the traxxas factory ESC's?
    Slash, Stampede,Craniac,X2 TRX4 ,ford gt 4 tec 2.0
  5. #45
    Dec 2003
    Dekalb, IL
    2,270
    Quote Originally Posted by lotust251 View Post
    The first one in the ERBEv1 you can. The MXL-6S is a castle MMv2 with traxxas badging. You have to get the castle field card or usb to adjust it. I got the field card since it can be used on it's own or with a computer.
