Results 1 to 25 of 25
    Oct 2017
    303
    Receiver blinking fast red but throttle and steering is ok
    I called traxxas and the guy told me this is impossible to have a fast blinking red light on the receiver and having the throttle/steering works.
    I have a Max6 as ESC.
    I unplugged everything on the receiver, leaving only esc and servo, bind again but led still red.
    Any suggestion?
    Dec 2017
    Van. Island British Columbia
    799
    You probably have tried but just have your receiver plugged in with no servo and do a factory default and then try and rebind.
    Mar 2016
    831
    Receiver inside clean and dry
    If Faulty acting
    Try different receiver-esc , etc
    fabricator
    Oct 2017
    303
    I will try with the TRA6518 (TRA6533 without TSM) tomorrow as I have to buy a second hand one. We'll see.
    Oct 2017
    303
    Ok TRA6518 installed and binded correctly.
    But unable to calibrate ESC... any clue ?
    Mar 2016
    831
    Wow
    Centered throttle?
    Try a different esc
    Have maxx on a stand/ pinion off white diagnosing
    Contact hobbywing direct
    fabricator
    Nov 2016
    Atlanta, Georgia
    943
    Sounds like a, hold on, let me call gio, oh yeah, sounds like a “Critical Era”
    RC Racer X-Maxx's Avatar
    Aug 2017
    141
    Quote Originally Posted by zeflex View Post
    Its the other way arround, #6533 has TSM and #6518 doesn't have TSM
    6s X-Maxx-Hobbywing MAX6 8s conversion
    Oct 2017
    303
    Yeah I know that but except the TSM both should work with the transmitter. So I presume the ESC is faulty but I am waiting a new tx/rx to make final test then call hobbywing. I hope it's under warranty (I never know if it's 6 month or 1 year...)
    Oct 2017
    303
    Well... I am an idiot. After a week I finally found I didn't plug the esc to the right channel that's why I was not able to calibrate it.
    BUT ... by the way, the receiver is still blinking fast red even if everything works fine. Weird
    If a Traxxas tech is interested, I can ship to them the receiver to investigate on what the issue is...
    Apr 2018
    797
    Have you tried moving the throttle trim back and forth to see if it might resolve your issue? It may be as simple as turning the throttle trim a bit. Not sure if anyone suggested this. If not, itís worth a shot.
    Aug 2017
    141
    Have you tried moving the throttle trim back and forth to see if it might resolve your issue? It may be as simple as turning the throttle trim a bit. Not sure if anyone suggested this. If not, it’s worth a shot.
    its on the receiver, the throttle trim is not on the receiver.
    Oct 2017
    303
    Well let's not update this topic anymore as the tx/rx works excepts this red blinking making no sense.
    13,391
    Is your telemetry installed correctly? Assuming you are using it?
    Jun 2008
    The land of confusion (Massachusetts)
    92
    I'm having this same exact problem as we speak. Did you ever come up with a solution??
    TIA
    Wile
    Sep 2018
    I'm having the same problem today.
    Is there a solution for it?
    Oct 2017
    303
    There is two times the CH1 on this receiver. I was connecting the wires to the wrong places (both ch1 was plugged and it should not).
    CH1 : servo only
    CH2 : esc
    CHxx: others
    Otherwise, if everything works (steering/throttle) and tx/rx is communicating fine and led is still red blinking, I didn't fix it. It work as a charm.
    I noticed when I opened the receiver, by putting my finger on some pins, the led was going from blinking red to green. So maybe something does an interference in the circuit but I don't know what...
    Jun 2008
    92
    Everything is plugged in correctly. I do get throttle and steering. According to traxxas instructions, a fast blinking red led on the receiver means it is in failsafe mode. It is because I don't get full throttle. The weird thing is that I see full voltage on the telemetry, and there is no error light blinking on the esc for low voltage...
    Looks like I'm gonna be calling traxxas...
    Wile
    Oct 2015
    906
    I had a similar thing happen this weekend, but I think it was caused because I was using two Traxxas TQi receivers at the same time. I ended up having to power everything off, update the firmware using the bluetooth module, and then bind each truck one at a time. It happened again later on and I ran out of sunlight. I will track my steps the next time. What was odd was the truck would steer in reverse but not in forward. I have never had that happen before.
    Nov 2018
    Cool I have same issue, and I fixed it.
    https://youtu.be/ll1tbIEY-wg
    Any suggestion?
    Jul 2018
    VIC, Australia
    83
    My X-maxx went on fire a couple of months ago and it had a new receiver fitted but now is blinking the red light fast but controls work. Updated all firmware (including telemetry) and still blinks fast. I'll pull the cover off and inspect the connector locations. Also my speed and tacho readings are way out of whack. It's reading top speeds of 500km/h
    Getting back into the RC game after 10 years!
    Oct 2017
    303
    Quote Originally Posted by morch_66479 View Post
    At least you beat all previous speed records
    Jul 2018
    VIC, Australia
    83
    SOLVED:
    So I fixed my issue where the receiver was blinking fast red:
    Turns out my RPM connector was plugged into the wrong port and was getting crazy readings on my speedo. The rpm lead loops into another connector so I swapped them around and all is good now.
    Basically the RPM & V/T connectors in the upper right hand side of the receiver were plugged in incorrectly so swapped them.
    Apr 2016
    3
    SOLVED:
    I did the exact same thing....except I had swapped BAT/CH5 and the V/T...dumb mistake on my part! Thanks for the tip :-)
    And I was about to dump all the TX telemetry and add more sensors to my Expander!
    San Diego, CA
    86
    I had the same issue in my X-Maxx 6s, had steering but no or erratic throttle, with fast blinking red light. The receiver firmware was updated and no change. Replaced the receiver and issue went away, not sure what took out the receiver or what made it fail but everything is working now with the replacement receiver. I did try the bad receiver on another rig, just to make sure and it was confirmed, the receiver was the problem.
    Sent from my SM-G955U using Tapatalk
    Summit; ERBE; E-Slayer; MERVs
    Wraith; AX10; RX10
