Results 1 to 18 of 18
    Feb 2017
    UK
    439
    Shock / Suspension setup
    Whats the best weight oil I should be using for general running on tarmac/dirt/grass.
    I won't be jumping big most often time, just some light jumps really....
    Whats the stock oil?
    I'm considering 50 weight Team Associated oil?
    Are stock springs OK for the running I will do?
    15,174
    The front will be fine for your needs. The rear however is way to soft.50wt oil will work, but also get the stiffest springs (1.5xx rate) for the rear shocks
    Ya can't polish fertilizer...
    Oct 2016
    4,021
    I run the 1.5 springs in the rear and the 1.4ís in the front. 65wt in the rear, 50 in the front.
    Aug 2012
    Alberta Canada
    1,185
    I had 40 and 45 weight available so I tried that and threaded the collars down a fair bit, maybe a very noticeable difference.
    If I don't break a shock before the next few months I may try 50/60 for front rear and proline dual rate spring kit.
    With my emaxx I found it the suspension was too stiff I would flip more on rough ground, so far by stiffening up my xmaxx got better, factory set up is too mellow for jumps or rough ground.
    Hard to get shock oil in good quantities so far I've only found losi racing oil in 16oz bottles.
    Sent from my SM-N950W using Tapatalk
    Feb 2017
    UK
    439
    Thanks guys.
    I may go for 50wt in the front and 60wt in the rear.....
    As for springs, which are generally best? Prolines?
    Oct 2016
    4,021
    Quote Originally Posted by Maxx_Adam View Post
    Lol. True. Coming from 1/10 cars. A bottle of shock oil is never ending. With this one does a little less than 2 shocks
    15,174
    I like more steering so I went with 40 wt and 1.2 springs up front. The front really doesn't bottom out even on big jumps.
    The rear still bottoms out with 1.5/50wt. I may go with 60wt in rear...
    Feb 2017
    UK
    439
    Seems the way to go.
    Maybe 40wt front, 60wt rear.
    1.2 Springs Front, 1.5 rear.
    Sound good?
    15,174
    Its def a good start. I would suggest just trying the rear adjustments first if ya can.
    The type of running described in the 1st post... The stock ft setup may be right on. I went up in rates and weights on the front only because I jump very big. It may save you 30$...
    Quick handling tip: if you want more steering(stock truck is set up to push from the factory), swap the front and rear differentials... The trucks rear end will loosen up, letting you get on throttle earlier when leaving turns... Try it its free 8)
    Feb 2017
    UK
    439
    Another question - which springs (ie manufacturer) do you use?
    I cant find any 1.5xx springs by Traxxas?
    Oct 2016
    4,021
    Quote Originally Posted by IftiBashir View Post
    https://rover.ebay.com/rover/0/0/0?m...2F192028703778
    Feb 2017
    UK
    439
    Awesome thanks!
    Feb 2017
    UK
    439
    I'm trying to reduce a lot of body roll around tighter turns etc.
    I think Im going to go with 60w oil and 1.5ww springs on the rear.
    I have a bottle of 40w oil for the front should I need it, but will leave stock springs on the front.
    Only other thing Im changing is the servo to the 2085x and the rear hub carriers to the oversized RPM.....
    Oct 2016
    4,021
    I went with 60 in the rear 55 in the front. 1.5 in the rear. 1.4 in the front. My truck is 30 lbs though.
    Feb 2017
    UK
    439
    I have access to 1.538 and 1450 rate springs - tempted to go with both while I have the chance.... not often they come into stock near me!!
    How come 30lbs?
    Do you have a build thread? Would love to get some more ideas!! lol
    15,174
    https://www.amainhobbies.com/traxxas...SABEgId5_D_BwE
    Oct 2016
    4,021
    How come 30lbs?
    30lbs is with batteries. Esc, motor, and wheels and tires. I do have a thread. Itís Grips Maxx build. You can search my name in the X-Maxx forum
    Dec 2017
    Wilmington,nc
    129
    I’m running 42.5 in the front and 50w in the rear on stock springs, perfect for my apps...
