Results 1 to 18 of 18
Thread: 1/8th Power
    RC Qualifier Madtrotter1's Avatar
    Feb 2018
    Washington
    250
    1/8th Power
    http://http://www.rpmrcproducts.com/...s-mxl-6s-escs/
    So i picked up a Mamba Monster 2 with a 2650KV and was wonder will the RPM cage fit or do i need to use velco to secure the ESC down. I have watch a few install videos and it looks like a tight fit. i have not seen a video that has used the RPM cage yet. Thanks guys
    Slash 4x4 /Stampede 4x4/Skully/Rustler VXL
    RC Champion lektro's Avatar
    Nov 2016
    Virginia Beach/ South USA !
    1,922
    I moved ESC up behind the front shock tower. Put the receiver where the ESC was. I have the 2200 though. Worked out quite well, I must say!
    Choose Life !!!
    Jun 2017
    Ohio
    1,328
    That's the same setup I used. It does lay everything out nicely. I made a little plate for underneath utilizing existing holes in the chassis and mounted the rpm mount to that. I don't run that setup anymore so I don't have any pics. There are a lot of build threads out there for this setup.
    Nov 2017
    Planet Earth...I think?
    541
    Hey Lektro, are you a “fan” of those W T F fans?(in your images above) ...pun intended...
    $+RC+more$+friends+more$=FUN!
    YouTube: EvHexRC1
    Jun 2017
    Ohio
    1,328
    Quote Originally Posted by EvHexRC View Post
    I'm kind of wondering the same thing. I've heard the Wild Turbo Fans are the shiznittybamboozle when it comes to fans.
    Feb 2018
    Washington
    250
    Thanks for the idea. I have a plastic plate from a VG brace that might just work for this
    Nov 2016
    1,922
    UM yeppers, I sure am a fan! A wild one too!
    Choose Life !!!
    Nov 2016
    1,922
    So how did you like that setup? You have same motor and all?
    Choose Life !!!
    Jun 2017
    Ohio
    1,328
    Quote Originally Posted by lektro View Post
    I liked it. I only ran the 2200kv in there for a short time after the whole what's better 2200kv or 2650kv debate started raging. I personally liked the 2650kv for me. The setup is good though, everything has it's place and runs nice and cool.
    Nov 2017
    541
    How do they compare to Yeah Racing? How do they compare to other companies?
    YouTube: EvHexRC1
    Oct 2016
    4,205
    YR are good for me. Plenty of air movement and they are holding up well for me. At a fraction of the cost
    Nov 2016
    1,922
    The wild turbo fans I really cant compare to the any other "one" i have tried which was Integy. The only good use I got out of that was wiring it up to drain some volts out of a battery when my charger is doing double duty. Still not very good for that.
    To be honest! I probably won't even use them. As Grip said once. I probably won't even need them. A lot of things I did to my p4de were just thoughts. The more I thought, I always seemed to make it real.
    Choose Life !!!
    Nov 2016
    1,922
    Yeah the more i think about it the more I probably should have gone 2650 which is what I have in my rusty. It's a perfect motor.
    Choose Life !!!
    Jun 2017
    Ohio
    1,328
    Running that combo in a stampede 4x4 I don't see a situation where you would need a fan. I have it in a pro mt 4x4 which is pushing 9lbs with a center diff, heavy diff oil, 18/44 gearing and I can run it full throttle for about 20 minutes on 4s and I've only seen the motor get over 155f once. I just realized you have the 2200kv. I was referring to the 2650kv, you will be even lower than that.
    Feb 2018
    Washington
    250
    this is one of my next projects what did you have to do make a 1/8 scale combo fit in a rusty
    Nov 2017
    541
    Thanks Lektro! I was thinking of using the W T F fans for SCT racing on a 3s lipo at my local RC track. It’s an outdoor off-road &th scale track.(by local, I mean an hour away from my house. It’s the closest one to me that’s still in business. It had actually gone out of business for a while.) I have to use a 3s lipo because it’s an 8th scale track with a 52ft. or more double!
    YouTube: EvHexRC1
    Nov 2016
    1,922
    The W t f fan is a powerhouse. I like the way they are built. Plus, they do put out some air. Sure the Y racing do too, but I can't give you a good comparison. Their mounts aren't cheap either. I found some generic mounts that worked out well. I plan on sandwiching them between two aluminum plates in the very near future. I will be designing the top and bottom holes with my sign software. I have a metal company down the street from where i work. I can send the design to them in a PDF file and he will water jet the design and polish. I am thinking that will look pretty cool. Just another thing I am doing because i can..... I just love doing this stuff.....
    That's sweet that you have a track to race on. I have heard of one around here called Debbies RC. She has indoor and outdoor tracks. I will get out there one day.........
    Choose Life !!!
    Nov 2017
    541
    I’d love to see those W T F fan mounts! Be sure to post pics of em! (Because you can)
    YouTube: EvHexRC1
