    Eastern Shore, Maryland
    4,579
    Teflon Liner Replacement
    I tried going back to using Teflon for a stuffing tube, but brass works so much better. With this little set up my boat is noticeably faster, my strut and tubes stay perfectly cool, no grease spooge on by boat, and my lube lasts longer. You can't beat it. I did update my set up though, by making my motor side of my tube a better fit.
    You can't do this with a Traxxas tube, because a Traxxas tube is slightly less than 1/4 inches. So, what I did was to use a true 1/4 brass tube to make a new guide tube, and on the motor side of my guide tube I soldered a 7/32 inch and then a 3/16 inch brass tube 1/4 inch deep in the motor side of my newly made 1/4 brass guide tube.
    Then when I slide my 3/16 inch stuffing tube/strut assembly into my 14 inch guide tube, everything fits nicely with my flex shaft/prop assembly.
    Here's the way I use to do it.
    Here's how I do it now.
    Here's the full three piece setup.
    And, here's a close up of the strut/brass stuffing tube assembly.
    Anyway, this works so good with my Spartan I had to go back to it.
    4,579
    This thing really works great! I wonder why RC boat makers use the Teflon tubing. I know for a fact that racers all change over to brass, but I wonder what the big draw is for Teflon coming out of the factory.
    Sep 2018
    54
    Is that og brasstube what you use?
    Lähetetty minun COL-L29 laitteesta Tapatalkilla
    4,579
    Quote Originally Posted by Speeder View Post
    This may sound silly of me, but I don't know what a OG is.
    Sep 2018
    54
    Original..... Can you give me sizes of brasstubes..
    4,579
    I did. They are at the top in the second paragraph above all the pictures.
