Results 1 to 2 of 2
    Jan 2018
    The driver seat
    144
    How big are the tires?
    Whats the outside diameter of the rear tires? I don't actually have a rustler/bandit so I can't measure them myself, but would like to use the wheels for a project of mine, and i'm hoping there not to big.
    RC Qualifier MECHANIC77's Avatar
    Sep 2016
    Canada
    429
    The outside diameter of the 2.8 stockers is exactly 34.2 mm and they are 10.5 mm height but if you needs for a smaller tire, it's possible to go with the 2.2 size wheels, then you will reach about 31 mm of diameter and a height of somewhere between 8.5 and 9.5 mm.
    Good driver. Bad setup. Bad things will happen...
