    May 2018
    4
    Try 3.3 how many crank bearing seals?
    I just put new bearings in my trx 3.3 and both bearings had seals in the front and back of them. Was I supposed to remove those seals on the rear bearing?
    13,498
    Were they bearings made specifically for the engine? I've pulled the rear seal from the front bearing and both seals from the rear - and installed the rear bearing with the race towards the back.
    May 2018
    4
    Yes, they were fast eddies sealed bearings for trx 3.3. The bearings looked the same on both sides. I just threw the small one in front, and the big one in the rear. I left both seals on both bearings. What does leaving, or removing the seals do?
    13,498
    Removing the seals allows the oils in the fuel to lubricate them. Plus the seals add a little drag.
    May 2018
    4
    Will having all the seals still on hurt the bearing, or anything else?
    RC Qualifier westoakmech's Avatar
    915
    Quote Originally Posted by Rust bucket View Post
    It should not hurt anything, the bearing should still get oil in it, it would just get in there bettter if the seals were removed. You have to remomber that little engine revs in the 30,000 rpm range. So any advantage to get oil to the bearings to keep them cool and lubed is better
    Rusty 2.5R,T-max 2.5 & 3.3,Summit VXL Nitro 4-tec
    Oct 2005
    South Florida
    19,487
    I've used these for years. IMHO well worth the money.
    https://www.avidrc.com/product/1/bea...-bearings.html
    Only the front one should have 1 seal on it facing the outside for best lubrication.
    All Lives Matter
