Results 1 to 22 of 22
    Jun 2018
    Connector question
    Hi all, first time poster. Hoping to get some advice.
    Just ordered a castle 1512 2650kv (and a bunch of other goodies). I called Castle and they suggested a 4s, min 50c/5000mah battery. which connectors should I use. I'm not into soldering and would rather go with a crimp on if possible. Was looking at the anderson stuff.
    Any suggestions? is SB175 overkill?
    Oh, and before anyone asks...
    Yes, I got a king headz motor mount, 19/54 RRP gears, cc blower and tekno m6 front and rear drive shafts
    The anderson PP120 says 6ga, most of the lipos are 10-12ga, correct?
    RC Champion shack351's Avatar
    Dec 2016
    Kville
    1,127
    Quote Originally Posted by bender77 View Post
    The brand that you use is your choice, but for a CC 2650 on 4S, I use a 6.5mm Castle Polarized connector. They work well. If you're not into soldering, take your batteries, ESC, Caps, etc to a local professional car stereo installer. I would not want any of my connectors simply crimped on!
    -Shack
    RC Qualifier Iansprouse1's Avatar
    Dec 2016
    Asheville NC
    439
    If you have a hobby shop in town you can just pay hem to solder them as well
    Slash 4x4, Stampede 4x4, SCX10, Bearded Dragon
    N. Idaho... Da Sticks!
    8,090
    You seriously DO NOT want crimp-on connectors, they are very high loss and even on 2S you'd melt the connectors. On 4S you are asking for a fire.
    20,550
    Connector question
    Are you lumping Anderson PowerPoles in with all other crimp connectors? One would certainly not come close to melting even the 30A version of these with 2S and to talk of fire is laughable.
    Note that the OP mentioned Anderson specifically.
    Alt-248 on the number pad = °
    Feb 2002
    9,412
    learn to solder
    Sep 2017
    8
    In modern aviation, high current applications are all crimped with little to no loss and there is no overheating. Soldering in aviation is a relic of the past. If you do not have access to high quality contacts & crimpers I would solder them.
    Traxxas Marshal
    Mar 2003
    Wherever the road takes me.
    38,021
    I'm glad someone said it before I got the chance to. Crimped power pole connectors are generally considered to be better than soldered when using a proper crimping tool. I solder mine (for lack of a proper crimping tool and reusability), but I wouldn't hesitate to use them if they were crimped.
    Welcome to the forums, by the way, Bender77.
    Dec 2016
    Asheville NC
    439
    I use Anderson connectors with 12v lead acid batteries. They need a special tool to be crimped for a proper connection. Anderson are good, while I don’t think the proper choice for RC. I use the large version used often with 6 gauge wire. The crimp tool is around $35.
    8,090
    Quote Originally Posted by cooleocool View Post
    Crimping is preferred to soldering because it does not cause a stress point in the wire like soldering does when the solder is wicked into the insulation. You can get a good low-loss connection with the proper crimper and someone that knows what they are doing, but do you think that is the case here? Without proper tooling and training for high-current crimp connections, you are asking for a fire. Before you talk about what is laughable, please take into account the experience of the person who is going the work.
    RC Champion MaXXL's Avatar
    Nov 2015
    South Florida
    1,222
    Oh boy. The ol' solder vs crimp debate.
    I work in aviation maintenance. We use both.
    I work(ed) in car audio. We use both.
    Crimped connections can be just as good as soldered and vice versa.
    We used to crimp 1/0ga terminals on 3000w car audio systems. Eventually we realised the terminals were corroding so we started soldering them after we crimped to prevent oxidization.
    That being said, if your gonna be in this hobby you should know your way around a soldering iron or find someone who does.
    I use my soldering iron quite often. Not just for RC but anything electrical. And it only costed me about $35 with the replacement tips and stand i also bought.
    10 RCs and counting 😅
    20,550
    And a bad solder job is any better? If you use an argument for one side, you have to be able to be able to defend against it on the other side. I think in this instance you cannot.
    Edit - additional thoughts:
    Since there is very little difference in cost between soldering and crimping, either for the iron/crimp tool the connectors, perhaps we should look at the method that would more likely fail in the hands of a beginner. It seems to me that a "strip insulation/insert wire into terminal/squeeze" sequence is hard to beat for simplicity and repeatability.
    It was not and never is my intention to disregard or minimize any of the dangers inherent in working with energy storage components. There is always some risk, and as Greatscott pointed out, that risk is accentuated by novice users with unfamiliar or inappropriate tools. However, contrary to what seems to have been said, those risks are not limited to a crimp connection. Full disclosure: I've installed hundreds of PowerPoles and various solder-type connectors over the last decade-plus with very few issues. Crimp-type connections were involved in none of those issues. That said - and taking the formerly available Dewalt harness kit from KD as an example - if done wrong ANY electrical connection can be a disaster waiting to happen.
    Finally:
    learn to solder
    C'mon man, this is spectacularly unhelpful and unwelcoming.
    Feb 2002
    9,412
    in a house, connections aren't allowed to e soldered.....
    RC Champion lektro's Avatar
    Nov 2016
    Virginia Beach/ South USA !
    1,922
    Yikes
    Choose Life !!!
    Nov 2016
    1,922
    I have never even thought of crimping connectors until now. I would say if it is rated at 600v yes it is a bit of overkill. I do like the connectors though. If I had seen this thread a long time ago, I am sure I would have considered using them over soldering. I am a pro at soldering now ( haha ) so I will stick with it....
    Am an old dog and was just taught a new trick.... Thanks Bender77!
    Choose Life !!!
    Nov 2015
    South Florida
    1,222
    In this hobby, there are certain instances where you cannot get around soldering. Like soldering motor or esc wires for example. Same goes for crimping.
    So if you plan on doing your own maintenance, you need to get comfortable with a soldering iron AND a pair of crimpers.
    Dec 2017
    North Texas
    631
    I'll throw in my 2 cents as an electrical engineer along with building custom cars, tig welding/fabrication, and remodeling homes I have a range of experience. I agree with many of the above posts. I tend to stay with the industry standards for the specific application:
    Homes = crimp / twist connections
    RC = solder
    Automotive = both
    Aviation / Aerospace = never owned one or done anything beyond some rivet jobs
    As far as connectors Castle Creations polarized 6.5mm as Shack351 recommended are great for 99% of people. An idea to consider the EC5 connectors are similar in their abilities, as well as being more common to find charger connectors or battery packs that already come with the option. XT-90 is becoming more common now also.
    I happen to have EC8 connectors on my car because it is playing in the 280-400 amp range (at 8s and might play with 12s later on)
    -Liberty
    Feb 2002
    9,412
    I run Genuine Amass XT-90 connectors. There are actually a lot of counterfeits out there
    I run an 1/8 scale SMC motor, Tekin RX8 gen2 esc, and an SMC 4s battery
    RC Qualifier NitroBugg's Avatar
    May 2018
    MS
    341
    I would rather solder all my connections personally. I've had more failures with crimps in practice. But to be fair...I've had a few cold solder joints along the line as well. It WILL happen. Been at it for over 40 years...so I just about got the hang of it.
    Being a "Ham" radio operator for 30+ years helped a lot too. Its not that hard...just get some scrap wire and practice. You'll get the hang of it in no time.
    20,550
    Have any more of y’all actually crimped PowerPoles with the correct tool?
    I used to terminate my wires with PPs while watching TV. It’s pretty darn easy.
    Feb 2002
    9,412
    learn to solder
    Ok, here is the the long version of this. Learning to solder is a great skill to possess, especially in the RC world. I personally did not like to solder initially, but found it a must. I discovered that soldering was made better and easier through proper tools, and research. I now have a Hakko FX888D solder station.
    Dec 2016
    Asheville NC
    439
    I have used both kinds. I agree with you that they are stupid easy to use and they are excelent connectors but I don’t they are the best choice for RC. The small ones aren’t big enough to use reliably for RC and the big ones are just too big.
